1978 - 1996 Big Bronco
AC not cold
Old May 16, 2006 | 09:25 PM
sirkt's Avatar
sirkt
AC not cold
Its getting warm here (broke high temp records 3 days running) as hot as 91 yesterday. Anyway yesterday I had to take the Bronco down the highway and went to turn the AC on the it didn't blow out cold, in fact it felt like the heater was on. So my question is do the DIY recharge systems work or do I need to bite the bullet and bring her to the shop to get the AC recharged? I like the idea of the DIY systems for two reasons, (1) I like to work on my truck myself, and (2) I am pretty cheap and the last time I check it was pretty high to have a shop recharge the AC. I guess I could just use the "3-55" air-conditioner but the AC would be nice for those longer road trips. My Bronco is a 1992 with the 302 V8 if that makes a difference.
Thanks all
Old May 17, 2006 | 01:29 AM
yamaweezle's Avatar
yamaweezle
you may not be low on freon...your problem could be one of several...even if the AC system is low on freon, there has to be a reason why...if there is a conciderable leak, charging it yourself is pretty much throwing money out the window...it will leak back out, and then your back to square one...i'd take it to a trustworthy shop, and have them sort it out...who knows, maybe you have a faulty compressor relay at best...could be that simple...
Old May 18, 2006 | 11:52 AM
93Mule's Avatar
93Mule
It's possible to check for leaks yourself. If you have enough pressure in your system, you can use soap bubbles to check for leaks. The only thing is depending on how bad the leak is, you may have to drop the whole freon charge to fix it. You would then have to hook a vacuum pump up to your system to remove air and then recharge the system. If you're just a little low on freon, I would say to just charge it up. If your system is way low charge, it might be better to have a shop look at it. It might also be another problem besides a low charge as was said earlier..
Old May 18, 2006 | 12:22 PM
Encho's Avatar
Encho
The Southernmost Mod
Also, the black box of the evaporator (don´t know if that´s the exact translation), wich is located to the left, against the firewall in the engine compartment, should be checked. If it isn´t properly sealed, the A/C system might be absorbing hot air from the engine directly to the evaporator and ventilator, not allowing the system to reach a proper working temperature and allowing dirt particles into the evaporator further increasing the problem by preventing it from "breathing".
Old May 18, 2006 | 01:03 PM
93Mule's Avatar
93Mule
True that...
Old May 18, 2006 | 01:32 PM
mirroman's Avatar
mirroman
I may be off target. Is the compressor kicking on? It may just be a switch.
Old May 19, 2006 | 04:49 AM
War_is_my_Shepherd's Avatar
War_is_my_Shepherd
What kind of money (ballpark) is involved in having a shop "re-charge" the AC?
Old May 19, 2006 | 07:41 AM
93Mule's Avatar
93Mule
If your truck was made before 95, it is probably running R-12, which is no longer in production because of the Clean Air Act. The only R-12 that is around is that which was stockpiled before 95. I think a 30 lb jug of R-12 is going for around $600 now days, so it will probably cost you between 30-40 dollars a pound (plus whatever mark up a shop is sure to tag on it). I'm guessing it would probably cost around $120-150 (refrigerant+labor) to charge a vehicle with R-12, depending on how low you are on refrigerant. If your compressor is kicking off and on like mirrorman was saying, your charge is probably a little low and the low pressure switch is causing the compressor to short cycle. In this is the case, you may be able to just top off your charge and be OK (if you can get your hands on some R-12). Here's some reading material..
http://autos.yahoo.com/maintain/repairqa/fluids_heat_air_conditioning_general/ques023_0.html
Old May 19, 2006 | 07:43 AM
93Mule's Avatar
93Mule
Let me try that link one more time.
http://autos.yahoo.com/maintain/repa...ques023_0.html
Old May 19, 2006 | 07:45 AM
93Mule's Avatar
93Mule
One more try..
http://www.epa.gov/Ozone/title6/609/recharge.html
Old May 19, 2006 | 08:08 AM
93Mule's Avatar
93Mule
http://www.familycar.com/Classroom/a...ANSION%20VALVE
Old May 19, 2006 | 08:34 AM
War_is_my_Shepherd
Thanks alot, posts #10 and #11 were some real good information.
Old May 19, 2006 | 11:56 AM
93Mule's Avatar
93Mule
No problem...
fred2001
Jul 10, 2010 06:51 AM
davisenvy
16
Jul 24, 2007 11:35 PM
TakeEm
Nov 7, 2005 09:21 AM
galaxie223
Jul 31, 2003 09:20 PM
gtex
Garage & Workshop
May 3, 2003 09:05 PM
