good morning i just picked up a fe motor from a 75 f100 xlt.
there is no block casting like the 352, or upside down 105, only a 14.
the #4 plug is broken in the head so i cant check the stroke with a wire. tthe block dos not have the ribbs on the sides. can this be a truck motor? i have to pull the engine yet but just currious what i have I bought the truck for 100.00 and thought it was worth the price just for the parts.
John a calculated guess is it's a 360. There were no 360s or 390s installed in trucks from the factory with 4 barrels. To be sure, you have well over $100.00 in parts.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
i looked up the vin code from the drivers door, it crossed to a f100 series two wheel drive 390 auto 4 barrel, Is there a mistake on the decoder sight? i am going to get the vin from home and post it to see what anyone else can decode. thanks
I may be wrong on this, but you should be able to measure the stroke in any cylinder not just #4. I've never done the dowel method although I keep meaning to. It's just I'm pretty sure I got 360's. But my understanding is you remove the plug, place a thin wire or something of the sort straight inside until it hits and then turn the engine over from the crank. Using a marker placed against the wire it should move back and forth from high to low and then just measure the mark of the marker. I offer this explanation so that if I'm wrong someone will point it out to me. I've never done it and wondering if I've got it right.
the vin plate says this
f15mcw86113
this is what the 70 to 80 cross ref link came out with. this intake has a lare T on the #1 Cyl intake runner were the S would me on other intakes, has anyone ever seen thison a intake befor? casting number on intake is D5TEXXXXXXX, and date code 5a26
Results for VIN#: F15MCW86113
Model Year: 75
Series: F150 - 4x2 Pickup
Engine: 8 Cyl, 390ci, 4bbl
Assembly Plant: Ontario Truck
Transmission: No code selected
Front Axle: No code selected
Rear Axle: No code selected
basicly i was trying to id the motor and this was the info I had i bougt the motor for my 71 f250 to replace the 360 when it goes.
just thought it was interesting since i have not sean a 4 barrel factory truck intake for a 360/390 was told it was never made. and wanted to see if it was a truck motor or not.
