Comp Cams Question?
Old May 14, 2006 | 11:54 PM
Jrock909's Avatar
Jrock909
Comp Cams Question?
I have a duration question on the Comp Cam 35-255-5.
According to the specs:
Comp Cam 35-255-5 $155
* Duration at .050 in.: 210 / 214
* Gross valve lift: 0.478 / 0.485
* Lobe separation: 114°
Will the duration of this cam cause me to have to install a stall converter on my 1992 Ford F-150 302EFI 4x4 Truck?
Old May 15, 2006 | 11:10 AM
Tech-man's Avatar
Tech-man
No, unless you wanted to.
Old May 15, 2006 | 12:57 PM
Jrock909's Avatar
Jrock909
How much HP will a camshaft give me alone?
Old May 15, 2006 | 04:44 PM
Kemicalburns's Avatar
Kemicalburns
hard to say what a cam itself would accomplish with out other things helping it. like headers and free flowing exhaust. intake, throttlebody upgrade etc... also depending on the mileage of your motor you might also want to get the valve springs upgraded to work properly with that cam. otherwise you may cause damage to the cam and possibly other parts.
in most causes a stall converter is not ideal for a 4wd, especially if you wheel alot
Old May 25, 2006 | 02:30 PM
73FOMO's Avatar
73FOMO
This is just a mild "rv" cam. It would take about 3 notches up before you would have to think stall...and then like kem said...street use. I would estimate 15HP maybe with no other adjustments.
bearster18
17
May 2, 2025 05:45 AM
UNTAMND
Feb 17, 2012 10:02 AM
77bigblock
Apr 17, 2007 02:18 AM
Jrock909
May 17, 2006 09:09 AM
jasonw302
Apr 6, 2005 09:41 AM
