No Forward power
Old May 14, 2006 | 05:28 PM
kwade66's Avatar
kwade66
No Forward power
I have a 1990 E-150 with 5.8 and when I put it in drive it is almost feels like a brake is on. It does not want to take off. Any suggestions on where I should look? Kurt
Old May 14, 2006 | 07:36 PM
ColonyPark's Avatar
ColonyPark
The very first thing to check is the rear brakes. Often the emergency brake cable will bind due to corrosion or damage. When this happens, you literally do still have the brakes on.
Old May 14, 2006 | 08:21 PM
Clubwagon's Avatar
Clubwagon
What transmission do you have? Sounds to me like the direct clutches are welded together. That puts the transmission in two gears at once when trying to start off and that feels like the brakes are on.
Steve
'95 Clubwagon XLT
Old May 14, 2006 | 10:04 PM
kwade66's Avatar
kwade66
I jacked the rear end up and both rear wheels turned freely by hand. On the transmission. I found some #'s on it. FTUP-7006-CB. It's a Automatic with Electronic Overdrive.
Old May 14, 2006 | 10:05 PM
pfogle's Avatar
pfogle
You have an early E4OD, it's probably given up the ghost. How many miles are on it?
Old May 14, 2006 | 10:07 PM
kwade66's Avatar
kwade66
It has 126,000 on it
Old May 15, 2006 | 07:46 AM
ColonyPark's Avatar
ColonyPark
Is it just me, or did anyone else catch the irony of his tranny part number? It starts with "ftup." Apparently, so is the tranny. :-P
Old May 15, 2006 | 05:02 PM
pfogle's Avatar
pfogle
Kwade, what you described sounds like a bad torque converter or a blown trans. Possibly both.
Old May 15, 2006 | 10:39 PM
kwade66's Avatar
kwade66
Thank you, You all were a big help!
russellkr
Nov 2, 2002 11:18 AM
beartracks
Oct 18, 2002 02:20 PM
dale i
Sep 22, 2002 09:37 AM
rogwelch
Feb 12, 2000 11:29 PM
Jan 28, 2000 06:08 PM
