ac pump clutch
Old May 13, 2006 | 12:11 AM
chrono4's Avatar
chrono4
ac pump clutch
on my 89, i cant get power to the clutch on the compressor, can i just run a toggle to it, and on which of the 2 wires do i need 12 on, and whats the other one for?
Old May 13, 2006 | 08:04 AM
Lazy K's Avatar
Lazy K
The problem with running the clutch from a direct wired switch is that you would bypass the low press. switch. This prevents the comp. clutch engageing if you are low on gas. You may have a faulty low press switch or you may be low on gas. As for the two wires I can only think that one is a ground. Get a meter and check the wires going into the clutch. If one is ground you will get a direct short reading with the other reading a resistance for the clutch windings. Good luck.
phoneman91
Feb 24, 2012 01:48 AM
WhiskeyRider
Jan 25, 2010 01:29 AM
keyes
May 7, 2008 08:19 PM
geotracker91
Apr 26, 2008 04:35 PM
JustinGustafson
Nov 16, 2006 01:42 PM
