tranny adjustments
Old May 11, 2006 | 04:39 PM
scouterspokane's Avatar
scouterspokane
Question tranny adjustments
ok, I will try this question in this section...
88 f150
4x4 AOD
when in reverse the tranny works fine, when placing in D or OD it takes a couple of seconds, maybe 5 sec, to engage...is there an adjustment for this or a regulator that needs to be replaced...the fluid is fine and is were it is supposed to be on the dip stick...
good campin to ya'
Old May 11, 2006 | 05:19 PM
quicklook2's Avatar
quicklook2
when did you last flush out the trans?
could be old fluid even if it does not look real bad, change filter, fluid and draining convertor may do the trick.
Old May 13, 2006 | 09:51 AM
scouterspokane
2 months ago along with the filter and new gasket, but I did not drain the convertor...
T. Kerger
13
Jan 13, 2011 11:31 AM
patricknivard
Aerostar
Mar 31, 2006 04:11 AM
goose213
Nov 11, 2005 02:08 PM
xltcrunch
Oct 16, 2004 01:00 PM
gingo70
Bronco II
Feb 16, 2004 09:36 AM
