Spare tire mounting options
Old May 12, 2006 | 11:41 PM
46fordtruck's Avatar
46fordtruck
Question Spare tire mounting options
Anybody ever relocated their spare tire on a '42-'47 P/U? I'm leaving the fuel tank in cab on 2 of my trucks (1/2 ton Ford and 1 ton), so I was thinking about under the bed, like '48 and later had. Any recomendations on a good donor truck to get a set up from? I just really don't like the spare on the side of bed, rather have the clean lines of the truck w/o it. These trucks will see plenty of road time, so running w/o a spare is not even an option.
Old May 13, 2006 | 02:58 PM
46achers's Avatar
46achers
The 48 and later spare tire hangers should be a "bolt-on" .
Dave
Old May 13, 2006 | 06:30 PM
3Mike6's Avatar
3Mike6
Hey gary,
I've a '48 out back, already sold the spare carrier, but can measure the frame width if you want to compare?
Lemme know.
Old May 13, 2006 | 06:57 PM
46fordtruck
Thanks Mike, I would be grateful if you could. I think they should be the same since the '42 started using the SAE standard for trucks, but double checking is always best.
Old May 13, 2006 | 07:35 PM
46yblock's Avatar
46yblock
Yes frame width is the same.
Old May 16, 2006 | 10:20 PM
howdy71475's Avatar
howdy71475
I have no doubt it will bolt on, but what about using something like a newer truck has. The new ones with the ratcheting cable tie down is kinda cool, and it just bolts on the the frame. I have one out here with a cattle gaurd and the spare mounted on the front, like an old jeep.another thought, but that really covers up the cool lines of the truck.
Howad
Old May 16, 2006 | 11:19 PM
46fordtruck
I have thought about one from a newer truck, with an easier to use mechanism, but figure I wanna keep it as simple as possible. The tire on the front is an idea, but with my '47 1 ton used as a tow rig and the '46 with a flathead, I want every bit of airflow through the radiator that I can get.
Old May 17, 2006 | 01:35 AM
46yblock's Avatar
46yblock
Howdy,
which trucks have the ratcheting cable tie down? I need a spare mount too.
Mike
Old May 17, 2006 | 01:56 PM
3Mike6's Avatar
3Mike6
I had a '85 or '86 Mazda B2000, that had one of what I think you guys are talking about, you'd use the jack lever/twister thing to unscrew a mechanism that lowered the rear tire down to the ground.
Old May 17, 2006 | 11:20 PM
howdy71475's Avatar
howdy71475
I know my father has a 94 ranger (same as a mazda) and a 2005 F250 that both have a cable tie down kinda mechanism. I would probably stay away from the 2005 one's. they put a hole in the bumper for the jack handle to work it. The 94 (I think) and I would have to check works from under the bumper. I didn't like the spare mounts for the 70's and 80's trucks seems like you had to crawl in the mud everytime you had to change a tire.
Howard
Old May 17, 2006 | 11:22 PM
45ford's Avatar
45ford
How about this recent addition to the "Articles/Specs" section?
Windstar_Spare_Tire_Winch_for_Vintage_Trucks.html
Mike
Old May 18, 2006 | 12:36 AM
46yblock's Avatar
46yblock
Wow, that looks like a winter project.
Old Sep 6, 2006 | 02:28 AM
bob s jr's Avatar
bob s jr
expoler spare tire carrier works but have to bake a frame bracket to bolt it to but closer to the older ford pick up frames
ton10291
16
Nov 19, 2012 10:19 PM
RAPR
6.7L Power Stroke Diesel
Sep 12, 2012 02:51 PM
deere55
Aug 19, 2012 03:14 PM
51dueller
Jul 14, 2006 08:59 AM
willport
1978 - 1996 Big Bronco
Aug 12, 2000 05:32 PM
