Limited Slips
Old May 14, 2006 | 02:55 PM
fruth04's Avatar
fruth04
they way i understood it as (i talked to a mechanic) on the ford rearends its designed to act more along the lines of a "wind up car" one tire spins (as if it is wrapping up a rubberband) and when i goes around soo many times it forces the other to start spinning, but in most cases this design doesnt work quite as it is spose to orr you tend to let off before the other tire ever gets a chance to move because if u are off road in many cases u could be stuck b4 the other tirre gets moving, we had it all figured out on my dads superduty when we were out mudding, i wish all trucks had posi, front lockouts like the superduties but on both axles so u could lock all 4 in at once
Old May 14, 2006 | 03:04 PM
Ruckus's Avatar
Ruckus
Smile
You guys are too funny!
Old May 15, 2006 | 06:15 PM
cullenkyla's Avatar
cullenkyla
I have LS in my truck and it works good. One wheel will slip the other will lock it
does not have to spin a lot either hope this helps take it back to the dealer and tell them to fix it.
Old May 18, 2006 | 11:52 PM
bear1's Avatar
bear1
a easy way of telling if you have the limited slip is to look at the rear diff tag if it has a L in front of the ratio number it is a locker
blloyd29
Mar 28, 2016 07:11 PM
horsepuller
Offroad & 4x4
46
Jan 25, 2014 09:08 PM
charlierogers
Sep 30, 2008 08:31 PM
jasonlasvegas
Sep 13, 2004 05:31 PM
Vaccuum
Sep 28, 2001 05:28 PM
