High Pitched Whine
Old Apr 28, 2006 | 03:09 PM
TOW II's Avatar
TOW II
High Pitched Whine
I notice a high pitched sound during acceleration to maintain speed, stops immediately when I take my foot off the gas pedal. I’ve got an ’04 F150, 2 WD w/ tow package. The truck has always made this sound. It’s not excessively loud, you really have to listen in order to hear it.
I’m assuming it’s the limited slip rear axle differential and (hoping) that it’s normal. Or do I need to have it examined?
Old Apr 28, 2006 | 03:39 PM
Biggziff's Avatar
Biggziff
Not normal. I have the LSD and get no such noise. I do get an intake whine when its really cold out...
Old Apr 28, 2006 | 08:55 PM
TOW II's Avatar
TOW II
I’ve never heard what a worn out differential sounds like, but what I’m hearing is about what I’d imagine it would sound like. Although it’s not very loud, I noticed it right after I bought the truck new. It’s been two years and 20,000, hasn’t got any louder, but it’s there so I guess I’d better have it checked out.
Old Apr 28, 2006 | 08:56 PM
Biggziff's Avatar
Biggziff
There have been others complaining of the same thing.
Old Apr 28, 2006 | 09:16 PM
TOW II's Avatar
TOW II
My first thought when I heard it was that they forgot to put oil in the differential!
Old Apr 28, 2006 | 09:18 PM
Dozer5's Avatar
Dozer5
YOu'd know that right away, had it happen. When you go around a corner, the rear end "chutters" and will shake the fillings out of your teeth.
Old Apr 29, 2006 | 11:46 PM
73f350sc's Avatar
73f350sc
My guess,
Vacum leak, maybye from a loose fitting like power steering or even brake power booster.
-Chris
Old May 1, 2006 | 07:50 AM
ford9c's Avatar
ford9c
Bring it in under warranty. It could be the ring and pinion. Ford had issues with the rear diffs mostly with the larger 9 3/4 limited slip units. Eventually it will get louder and it could get real expensive if its no longer under warranty.
Old May 2, 2006 | 12:01 AM
halfloop's Avatar
halfloop
Warranty issue take it in
Mine did the same. Take in for warranty as suggested. Some dealers do kit. Mine was the whole rear end replacement. Cheaper than the labor for the Kit.
Old May 2, 2006 | 10:57 AM
blub's Avatar
blub
Mine did the same thing, I still cannot pin it down. It happens uphill while accelerating, as soon as I let off the gas it stops. I cannot tell if it's the rear end, tranny or motor. My wife hangs her head out the window to listen but shes not very good at identifying where the noise is from, it's sorta like a whistle coming from the right side and I can't remember if it's in a certain gear or not. I've taken it to the dealer but there are no hills in the dealer parking lot to test it.
Old May 2, 2006 | 01:47 PM
TOW II's Avatar
TOW II
I notice mine more while cruising at speed, on level ground 60-70 mph. I'm thinking differential because it's only during acceleration. The Michelins on my truck actually make twice as much noise as the whine I'm hearing. You have to listen very closely, then it's like you said "as soon as I let off the gas it stops", tap the acccelerator and I hear it again. I'm goiong to take it to Ford, hopefully they'll make an accurate analysis. I also have rear brake rotor issues, rotors are grooving excessively on the outer surface only, inner surface is smooth.
Old May 2, 2006 | 05:47 PM
liquidc11's Avatar
liquidc11
had the same problem and the dealer warrantied it. it is all fixed. let me pull out my service invoice and i will tell you exactly what they did. both the wining at highway speed that went away when i got off the gas, and the rear end chatter around a corner
Old May 2, 2006 | 05:50 PM
4wdriver's Avatar
4wdriver
mine to,but i stopped the hi pitch wine by letting out my wife.
Old May 2, 2006 | 06:08 PM
liquidc11's Avatar
liquidc11
TSB 05-23-03 bad pinion, ring, and bearings.
was the whinning noise
And A bad rer diff. and limited slip was the shuttering around corners
it is all good now
Old May 3, 2006 | 08:42 AM
TOW II's Avatar
TOW II
it is all good now
Thanks for the advice! Cornering is smooth, but I have noticed the whining has gotten louder. I'll be having it serviced soon.
