02 Ranger FX4 Check Engine Light
Old May 9, 2006 | 10:07 PM
MRStace84's Avatar
MRStace84
I have a 2002 Ranger FX4 with 47,000 miles on it. It has the 4.0L motor and 5spd manual tranny. Today my check engine light came on, and it won't go off. All of my fluids levels are ok, and the truck runs normal. Any ideas what might be wrong? Just checking to see if this is a common problem.
Old May 10, 2006 | 12:50 AM
Rockledge's Avatar
Rockledge
Go to Autozone and get the codes pulled for free. Without the codes, it's like looking for a needle in a haystack.
Old May 11, 2006 | 09:25 AM
pawpaw's Avatar
pawpaw
I agree with Rockledge, have the computer scanned for stored trouble codes.
Most autoparts stores will do it at no charge, if the Check Engine light is on.
Just wondering, did you maybe just fill up & forgot to tighten the cas cap until it locks????
Post ALL the codes found!!!!!
Old May 11, 2006 | 02:58 PM
soundwave's Avatar
soundwave
Will Auto Zone really do it for free? When the light came on in my old '95 Splash about 8 years ago, a certain auto repair shop( Pep Boys) told me it was $75 to hook it up to find out the codes.
Old May 11, 2006 | 03:07 PM
Rockledge's Avatar
Rockledge
Autozone will do it for free where you live.
Old May 14, 2006 | 11:26 AM
MRStace84's Avatar
MRStace84
The code I am getting is P0402, and the description if EGR Flow excessive. Any idea what I need to look for?
Thanks
Old May 14, 2006 | 12:03 PM
pawpaw's Avatar
pawpaw
The DPFE sensor is a common problem for this code, it controls the EGR valve & if the DPFE acts up, it can cause the EGR valve to also act out. So check it's vacuum lines, gaskets & mounting bolts, then test it. Look in the "Technical" thread atop this forum for details on the DPFE.
If the DPFE checks out ok, also check your EGR valve for excessive deposits that might cause it to stick open.
Let us kow what you find.
Old May 15, 2006 | 11:11 PM
PW01's Avatar
PW01
I had the same problem, DPFE sensor fixed it
Old May 25, 2006 | 08:54 AM
MRStace84's Avatar
MRStace84
I replaced my DPFE sensor, seemed to have fixed my as well.
