another generic question
Old May 9, 2006 | 06:42 PM
BIG66PROJECT's Avatar
BIG66PROJECT
I'm getting a donor truck,71 F-100 with front disc brakes.what all do I need to pull of it besides rotors and calipers and master cylinder I dont need the whole the front end set up do I? is htis a pretty simpple install?
Old May 9, 2006 | 08:22 PM
66beater's Avatar
66beater
you need the spindles too, but unless you want to have a machine shop rebuild your kingpins, it might be easier to just grab the whole I beams. its actualy fewer bolts to remove the whole I beam (2 plus shock and spring retainer). you also need the proportioning valve to go with that master cylinder
Old May 9, 2006 | 08:35 PM
BIG66PROJECT
thanks
Ya i was just wondering what to grab cause the truck is going to the bone yard,anything else I should grab for my 66
Old May 9, 2006 | 10:33 PM
customcab66's Avatar
customcab66
Don't quote me on this but I think all of the running gear is the same. If I were you I would take the rear end and springs and such just to have spares.
Old May 9, 2006 | 11:27 PM
BIG66PROJECT
8.8
the guy told me the truck has an 8.8 rear end in it I could prob get the springs and another nic nacs
Old May 10, 2006 | 01:18 AM
daveengelson's Avatar
daveengelson
Believe will need the later I beams that will accept the spindle and calipers. Suggest taking the pedal setup, and/or stop light switch. I kept the original pressure stop switch setup. Also, check for brackets and pulleys 2 or 3 groove.
dave
Old May 10, 2006 | 04:41 AM
jowilker's Avatar
jowilker
big66, You might want to start shopping somewhere else. The 8.8 wasn't introduced until the mid 80s. I think it was offered before behind a 5.0 but it was 1986 before the 9" was dropped completely.
John
Old May 10, 2006 | 07:15 AM
BIG66PROJECT
tahts what i thought
I'm just going to take the whole truck and take everythin I can off of it then I'll have spare 9" to narrow,also came across a 67 steering column off of a manual witch is cool cause I don't want the shifter lever on the column cause I'll be using a rachet shifter this should bolt right in correct?
Bltfordtuff
1997 - 2003 F150
Jun 3, 2013 06:59 AM
dadsranger
Feb 6, 2010 10:38 PM
Brown Falcon
Feb 7, 2009 07:02 PM
Fomocosho
Jun 4, 2007 09:50 AM
1972ford_f-100
Apr 11, 2005 12:40 PM
