ebvp removal??
Old May 12, 2006 | 06:13 PM
mtgrzlyman's Avatar
mtgrzlyman
i had the banks power elbow installed at a shop is there anything i should worry about or ask them after reading this?????
Old May 13, 2006 | 12:04 AM
mtgrzlyman's Avatar
mtgrzlyman
ttt just curious
Old May 13, 2006 | 12:02 PM
cruise409's Avatar
cruise409
ttt just curious
You're fine, if you already have the Banks in. You just may have paid a little more for the Banks than the Gillette. From what I read, they basically both do the same thing: remove the EBPV and increase exhaust flow. It's all about the all mighty $$$.
Old May 14, 2006 | 10:58 AM
jtharvey's Avatar
jtharvey
I'm not familiar with how the Banks power elbow is installed or made, but it depends on what's been done with the EBPV rod. If it's been left hanging or the sensor is plugged in, you could run into problems.
But, as expensive as Banks stuff is, it's usually well engineered and I would only imagine that they've got a place for the rod to fasten to the elbow, just to hold it in place, and perhaps some sort of code fooler for the EBPV electrical plug. However, without being able to look at it, I can't say for sure if there would be a problem or not.
officer131
Mar 21, 2015 03:26 PM
High Intentions
Mar 26, 2014 04:24 PM
Bossman7121
20
Jun 12, 2013 11:19 AM
szotty
Dec 17, 2011 07:32 PM
99powerstrokeSD
Feb 11, 2007 09:00 PM
