faulty vss?
Old May 9, 2006 | 09:13 AM
pinesman's Avatar
pinesman
faulty vss?
Has anybody ever purchased a faulty vss? The dealer diagnosed and replaced mine but it still seems like it is not right. The E4OD wants to shift way too soon, especially out of first. Could the new vss be bad or is there something mimicing the problem? They reflashed the computer and it did not help. thanks.
kb
Old May 9, 2006 | 01:30 PM
1997F-350's Avatar
1997F-350
it could be the new shifting parameters of the new pcm code that you are not used to.
Old May 11, 2006 | 11:13 AM
pinesman's Avatar
pinesman
I had thought about that. However, with a 10,000 pound trailer behind it, it is shifting way too early. It seems to do only do it when the truck is warm. I had even wondered if the oil in the rear was getting hot and altering the signal. Any more ideas would be greatly appreciated. It is not throwing any codes and my dealership mechanic probably thinks I am imagining it all. thanks
Old May 11, 2006 | 01:02 PM
DaBigTow's Avatar
DaBigTow
The signal from the VSS won't be altered by heat; too much heat would make it pulse on & off or shut it down completely as the clearance between to VSS and exciter ring grew. Any change would be immediately visible on the speedometer.
Old May 11, 2006 | 01:54 PM
Jerme's Avatar
Jerme
My truck started shifting too soon and it would shift in/out of OD at random times. Turned out my programmer didn't return the full stock code when I took it out, so I'm waiting on a new pcm from dp-tuner.
SBastow
Jun 24, 2009 08:54 AM
fido74
Jun 5, 2009 02:50 PM
DJdemon6696
Aug 1, 2007 07:56 PM
jboard
Apr 8, 2007 05:32 PM
buckethead5k
Dec 18, 2006 10:07 AM
