Erratic shifting torqshift???
Old May 9, 2006 | 12:52 AM
Brian460's Avatar
Brian460
Cool Erratic shifting torqshift???
My torqshift has a very delayed reverse engagement, delayed drive, but not always. The 3-4 upshift will sometimes hit neutral for a few seconds then bang into 4th.
Here lately it doesn't seem to know what gear it is in sometimes, like I can manually put it in 1st yet it will remain in 3rd even at a dead stop.
It almost acts like an electrical problem.
Old May 9, 2006 | 01:49 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
My guess is that you probably have a wire chaffing problem. You may also need to be reflashed, but I'm leaning more towards the wire chaffing issue. It seems like it's more of an electrical problem than it is mechanical.
Old May 9, 2006 | 05:48 AM
Brian460's Avatar
Brian460
I forgot to mention the other day the tow/haul light was flashing.
It also has the most recent flash from Ford.
Old May 9, 2006 | 07:52 AM
Casey's Avatar
Casey
When the tow/haul light flashes it means the computer found a problem. Get it in ASAP before it dies!
The code will stay in memory even if the light isn't flashing any more.
Old May 9, 2006 | 10:18 AM
Brian460's Avatar
Brian460
Had a friend plug the truck in to his computer, it has no codes set for the tranny.
Old May 9, 2006 | 12:08 PM
Casey's Avatar
Casey
That means that your friend didn't have the right software to read the codes on the TorqShift. The code is there, but he couldn't read it.
Old May 9, 2006 | 12:15 PM
Brian460's Avatar
Brian460
Ford found nothing wrong with it either on the computer they said they would have to tear into it.
Old May 10, 2006 | 12:20 PM
l-m tech's Avatar
l-m tech
did they give you any info to what it might be.i would be leaning towards the mecatronics unit in the trans or sticking pressure solinoid.
Old May 10, 2006 | 04:12 PM
Brian460's Avatar
Brian460
They just said they would have to do some more looking into it. I wasn't there very long.
andrewzx92000
Jun 8, 2011 01:31 AM
Evan99
Apr 6, 2010 01:08 AM
plowin4u
Mar 6, 2010 04:31 PM
plowin4u
Dec 30, 2009 08:04 PM
Brian460
Sep 22, 2006 10:25 AM
