np435 transmission
Old May 8, 2006 | 06:30 PM
mikefender's Avatar
mikefender
np435 transmission
I recently purchaced a 2wd np435 transmission for my 1977 f250 highboy divorced.Can I just swap the output housing from my old np435 so I have some place to mount the transfer case shifter or do I need to replace the output shaft as well?Both have slip type yokes not the flanged type.
Mike
Old May 8, 2006 | 06:52 PM
FordPickup460's Avatar
FordPickup460
I put a 2wd NP435 in my Highboy to replace my C6 and I made a bracket that bolts to the top of the tranny and down to where the tailshaft bolts to the case for my 4wd shifter to bolt to and pivot.
Old May 8, 2006 | 08:00 PM
havi's Avatar
havi
I'll have the Roast Duck
To be sure, remove both tailhousings and compare the tailshafts. I think they should be the same.
Old May 8, 2006 | 09:28 PM
averagef250's Avatar
averagef250
Yes, the 2wd and 4x4 435 divorced tailhousings are 100% interchangeable. Done it a dozen times.
petrovich79f250
Dec 19, 2020 09:37 AM
cardio75
Jan 5, 2005 07:51 AM
Goodold71
Feb 4, 2004 11:21 PM
aunchman
Aug 5, 2002 04:55 PM
90Bronc
Feb 27, 2002 05:01 PM
