Help ASAP Please!!
Old May 24, 2006 | 03:35 PM
  #46
chrisf's Avatar
chrisf
I've pulled my valve covers four times now. I'm pretty good at it and it takes me a little under two hours by myself with normal tools.
You might look at the thread about hard cold starts. It's full of descriptions for glowplug removals with lots of tips on how to get the covers off quick.
Old May 24, 2006 | 03:53 PM
  #47
cobaum's Avatar
cobaum
Valve cover removal
Hi, John. I started with the drivers side as there is less to remove. It took about an hour and a half. It was straight forward with no hidden tricks that I can help you with. That fixed it on mine and I have yet to do the passenger side (with much more to remove). I will get to the passenger side if and when it needs it.
Old May 24, 2006 | 06:16 PM
  #48
john day hardy's Avatar
john day hardy
Well, as luck would have it, it's the passenger side. The good news is, it seems to be the external connector. I got poking around with the engine running, and pushed down on the harness. Had, Jan, my wife inside watching the service engine light. Every time I pushed down, the engine smoothed right out, and the light went off. Now, I am mechanically inclined, but dipped if I can see how to disconnect the connector. I reall can't see into that spot well enough. Any tricks?
Old May 24, 2006 | 06:45 PM
  #49
Kwikkordead's Avatar
Kwikkordead
External apperances are decieving. It's easier to remove the passenger side.
Old May 24, 2006 | 09:56 PM
  #50
Grunt0311's Avatar
Grunt0311
I would pull the valve cover. I would be willing to bet that inside where it connects to that external harness it is loose. Not a bad job, just takes patience getting the back bolts loose. Some of them can be reached easier through the wheel well.
Good luck!
Bill
Old May 25, 2006 | 04:43 AM
  #51
john day hardy
Thanks for the help guys. Looks like wrench time. When I get it back together, I'll post with an update.
Old May 25, 2006 | 05:29 PM
  #52
john day hardy
My Stroker lives!!! Took my time and did it in four hours. Once I got the valve cover off, I found the plug had come out close to half way. The harness looked good, but since I had it apart, I replaced it anyway. For $25.45 at the International garage with a package of factory shims [3]. I like going there, they know diesels, and have some big trucks to drool all over.
Can't thank you guys and this site enough. I not only saved a few hundred bucks, but I learned a few things too!!
Old May 25, 2006 | 05:38 PM
  #53
PSNut's Avatar
PSNut
Very cool!
Nut
Old May 25, 2006 | 06:45 PM
  #54
rickgmi's Avatar
rickgmi
You could have used an few quarters and saved enve more...good job
Old May 25, 2006 | 07:08 PM
  #55
PSNut's Avatar
PSNut
One way u can thank us is becoming a site Supporter! Best $15 investment you'll ever make!
Nut
Old May 25, 2006 | 07:37 PM
  #56
Grunt0311's Avatar
Grunt0311
I'm glad to hear you got your mule fixed! Feel free to ask any questions you may have!
Bill
Old May 25, 2006 | 08:50 PM
  #57
Kwikkordead
Very cool. Glad you got it fixed.
Old Sep 7, 2006 | 02:15 PM
  #58
biggame's Avatar
biggame
Do you still have the pic of the quarter under the clip to hold them up? I have the same problem and am working on it tomorrow, the pic would come in handy if you still have them. If so, could you email them to eds110@hotmail.com? Thanks in advance.
Old Sep 7, 2006 | 02:56 PM
  #59
rickgmi's Avatar
rickgmi
yea still got it....ill send it to yout hotmail...it real easy just gring the quarter down to where you just have washingtosn head shaved flat about a 1/16 of an inch
slowlanemcvane
Jan 28, 2016 08:53 PM
mikerans
Bronco II
Nov 17, 2012 09:31 AM
87f250banks
23
Jul 2, 2010 09:39 PM
scottinjaxf250
Jun 4, 2010 08:53 AM
