Yellow Three-Prong Vacuum Plug
Old May 7, 2006 | 09:59 AM
LARIAT 85's Avatar
LARIAT 85
I found what looks like a broken vacuum plug at the back of my engine. It is yellow, sticks up about an inch from the very back of the engine on the right (driver's) side, and has three prongs that stick out of it. The previous owner had cut and plugged all three ports with screws, and I just found that the whole yellow vacuum plug had broken off. Can someone tell me what these three ports went to?
There is another similar one on the front of the engine, where the water pump is. Same yellow color, three prongs that stick out of it, only this one is in good shape with a top vacumm line running to the back and the engine and the last two are comnnected to each other with a half inch piece of hose. Can someone tell me what these bottom two ports once led to?
I do not understand the vacumm diagrams, so if anyone has any pictures, that would be a big help. THANKS!
Old May 7, 2006 | 01:25 PM
sierraben's Avatar
sierraben
Give us what engine you have so someone may be able to help you.
I'm guessing you have an '85 F150.
Sounds like a "thermal vacuum switch".
Old May 7, 2006 | 08:43 PM
LARIAT 85's Avatar
LARIAT 85
Of course, how stupid of me! I can't believe I forgot to post what I had!
1985 Ford F-150 XLT Lariat
302 2-Barrel V-8 (original rebuilt Motorcraft)
THANKS!!
P.S. Did most 302 V-8 F-150's in 1985 come with a carburetor, or did most have the fuel injection?
Old May 8, 2006 | 12:02 AM
sierraben's Avatar
sierraben
LARIAT 85, you stated on the right (drivers side).
Didn't realize you had a European Ford truck.
Driver side is the leftside.
Did you mean leftside?
Old May 8, 2006 | 12:28 PM
LARIAT 85's Avatar
LARIAT 85
YES, I mean the left side. This always confuses me. I was going by standing in front of the hood; in which case it would be to the right, and on the driver's side. I guess if I were to sit INSIDE the truck, it would be the left side.
Thanks!
Old May 8, 2006 | 05:19 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Without a vacuum diagram, and picture of the part, I wouldn't even hazard a guess to what it could be for. Almost anything really. EGR system, Thermactor system, Evaporation system, spark advance, air duct heat riser system, etc.....
A thermal vacuum switch sounds acurate. Manifold vacuum goes into one side, and depending on the tempurature, switches the vacuum between the other two ports.
Does part of it go into the water jacket?
Old May 8, 2006 | 06:08 PM
Jeff Fisher's Avatar
Jeff Fisher
on my 84 w/460 the rear vacuum port has 3 different sized ports on the one fitting, one goes to the pwr brake, one goes to the cruise control, and the third??? I guess I will find out when I get to that point of reassembly.
The front ones go to the polution crap, egr and air pump devices via a temp switch on the coolant outlet fitting.
Jeff
LARIAT 85
18
Jan 23, 2014 07:28 PM
bomberboat
Jul 26, 2011 02:36 PM
stang_crazy_gt
Oct 25, 2007 12:14 PM
LARIAT 85
Sep 5, 2007 06:04 PM
Stephan
May 29, 2002 07:36 AM
