Please help on replacement carb
Old May 6, 2006 | 09:52 PM
madcowranch's Avatar
madcowranch
I have a '72 F600 grain truck that I'm trying to get running for wheat harvest. It has a 361 with 2 barrel intake and manual choke.
Does anyone know what carb (cheap preferably) I need to order for this thing?
Old May 6, 2006 | 11:10 PM
markjw's Avatar
markjw
If you have the original carb you might try these folks. http://www.carburetorfactory.com/ ....You send them your carb and they rebuild it rather than send you something that may not fit. They will email you an est. if you send them the No.'s on you carb...They did a 2bbl holley for me for about $120...Works great.
Old May 6, 2006 | 11:19 PM
ford390gashog's Avatar
ford390gashog
that truck will have a autolite 2100 carb super simple to rebuild order a kit for a f-250 truck with a 390 for that year and it will ocst you about 14.00 and 2 hours worth of work. you will also need a new mounting gasket and a few cans of brake cleaner.
Old May 7, 2006 | 07:12 AM
madcowranch
Sorry, I should have been more clear- someone has robbed the carb off this thing at some point so I don't have a point of reference or anything to rebuild.
Old May 7, 2006 | 07:26 AM
mr.james's Avatar
mr.james
My 2bbl. for a'70 390 cost me 90 bucks at the local auto parts store. works great.it was an exact match.
Old May 10, 2006 | 01:07 AM
Cracker289's Avatar
Cracker289
You should have no trouble getting the right carb for it, walk into Autozone or Pep Boys or whatever and tell them it's a 72 Ford F600 with a 361 and they will have the right one for you. About $100 or so, depends on whether it has electric choke and some other stuff like that, I am not sure.
Old May 10, 2006 | 01:12 AM
OrdoDraconis's Avatar
OrdoDraconis
mine is a holley 2100 its abut 130 bucks withacore charge at csk auto
Old May 10, 2006 | 01:19 AM
ford390gashog
no parts store will be able to look up anything past a f-350 truck. if you want a simple and reliable carb that is a close match to the the stock one go and buy a 2 bbl carb from a 1972 ford f-250 truck. it will have the 1.23 bore and is super simple and reliable.
Old May 10, 2006 | 01:40 AM
Cracker289's Avatar
Cracker289
Well I did not know that the heavy duty trucks were not in the system. After ford390gashog mentioned that, I checked autozone's webpage, and sure enough, only goes up to 3/4 ton trucks. But, definitely a 2-barrel from a 72 F-250 with the FE motor would work fine. BTW, I checked for 72 F250, and they have the same part # for 72, whether its a 302, 360, or 390. Holley (reman) part 64-5337, and it's $149. Ouch! Plus $35 core!
Old May 10, 2006 | 01:43 AM
ford390gashog
you can always get a new 500 cfm holley 2bbl from summit for 219.00 www.summitracing.com or ebay autolite carb or motorcraft 2100 carb
Old May 10, 2006 | 04:18 AM
madcowranch
I guess O'Reilley gave me the wrong carb. It has the heat riser choke thing and heater hose clip. I assume these are are critical to make the choke work and I don't know how to plumb the heat riser deal and the heater hose is just a loop bypass. Can't I just get a manual choke?
Also I have 3 vacuum lines coming out of my distributor to carb. How am I going to know where to hook those up?
Old May 10, 2006 | 01:28 PM
ford390gashog
take a picture of the distributer i have never seen any setup like that. i may be able to help if i can see where the ports are.
Old May 10, 2006 | 07:07 PM
madcowranch
First is passenger's side, second is driver's side.
http://pic20.picturetrail.com/VOL131.../145782084.jpg
http://pic20.picturetrail.com/VOL131.../145782068.jpg
Old May 10, 2006 | 08:09 PM
madcowranch
Man, I was looking at rebuild kits online for this thing. $550 for a Master rebuild kit was the cheapest I found. Might as well just start looking for a good used motor if it comes to that.
Old May 12, 2006 | 12:48 PM
madcowranch
Would any big block Ford be a simple drop in on this thing if I decide to swap motors?
