How did you check for spark useing the plug or a spark tester? I have had coils that were weak and would spark across the plug but would not fire under pressure. Once checked with a spark tester there was no spark. Have you noticed any corroded connections or bag grounds? You may also want to check your compression to make sure it is good.
might want to check all of your electrical wire behind the manfold, and make sure some mice or other creatures chewed throught them, the main plug for the injector harness plugsup directly behind the motor, right above the head.
