Electric radiator fan?
Old May 5, 2006 | 09:04 PM
Hellbore's Avatar
Hellbore
Has anyone had any success switching to an electric radiator fan on one of these older FE engines, like a 390? If so, what size and brand did you go with?
I did this on my SUV and I loved it, the engine sounded nice without the fan. I would wire it up with a thermostat and everything so it wouldn't kick in until necessary.
I also think it would be nice for AC purposes because I would mount a secondary fan on the AC condensor to improve AC performance.
Anyways just wondering...
Old May 6, 2006 | 06:14 PM
Randyb12's Avatar
Randyb12
The off road guys really like the Taurus fans from the 3.8l models. All the aftermarket fans that pull enough air are too expensive. I am running a fan out of a camero.
Old May 6, 2006 | 06:18 PM
Hellbore's Avatar
Hellbore
So is that to say that the standard aftermarket fans like the 18" ones at Autozone, don't pull enough air?
Old May 6, 2006 | 06:29 PM
Randyb12's Avatar
Randyb12
I don't think they will do it under a heavy load or idling in very hot weather. But every engine/cooling system is different. The thing about Big chain places like AZ is if it doesn't work then you can usually take it back. This is one of those things you are just going to have to do some trial and error until you get it right.
But one of those wired to a thermastat and one in front of the A/C condenser wired to the A/C may work. Only one way to find out.
Old May 6, 2006 | 06:32 PM
Hellbore's Avatar
Hellbore
I dunno about idling! Usually the opposite is true, usually electric fans are BETTER at cooling an engine at idle than the normal fan, because at idle, your normal fan is not turning very fast, so it's not moving as much air at low RPM...
An electric fan on the other hand is moving MAX airflow no matter what even if you are idling.
Old May 6, 2006 | 07:06 PM
Randyb12's Avatar
Randyb12
He is asking about the cheap 18 inch fans from AZ. Greg had some issues idling with the expensive BlackMagic fan also. I don't remember exactly what he did to fix it. mayBe he will chime in.
Old May 7, 2006 | 05:13 PM
lokeraz's Avatar
lokeraz
i got one from a lincon mark8 and that thing pulls air like crazy,, i have it with a on/off switch, ill post some pixs of it!
Old May 7, 2006 | 05:18 PM
Randyb12's Avatar
Randyb12
I heard a couple of people memtion those lately. How do you like it?
Can you compare it to a Taurus fan?
Old May 7, 2006 | 05:39 PM
lokeraz's Avatar
lokeraz
dont know much about the taurus ones,, but i had this one in my 93 bronco and never had any problems with it,, in heavy traffic or pulling, thats way i took it off the bronco before i sold it lol!!
Old May 9, 2006 | 03:39 PM
biz4two's Avatar
biz4two
Arrow
I went with a flex-a-lite electric dual fan setup on my 390FE. Works fantastic...and can idle all day or pull a 5000lb load without any over heating issues. Has a max of 4600cfm, but will only use 60% until the full 100% is needed. So it helps with the charging system too.
http://www.flex-a-lite.com/auto/index.html
27" Electric Fan (dual 13.5"), Part #295
FYI...I also changed out my factory radiator. Installed a Griffin aluminum direct bolt on radiator. Plus upgraded the water pump too. Use an Edelbrock aluminum water pump.
http://griffinrad.com/
It is a sweat setup...and no issues thus far.
biz
_______________________________
1976 F150 LWB 390FE NP435 NP205 4x4 3.50s
BGF100
Jul 24, 2017 04:04 AM
Kelley11
May 22, 2015 01:54 PM
Skauber
May 14, 2015 12:42 AM
orangeford
18
Feb 27, 2015 03:24 PM
Dannym
Jun 27, 2005 10:56 PM
