Sponsored by: Auxito
HELP... having hesitation problems!!!!
Old May 5, 2006 | 02:11 PM
surf2wake's Avatar
surf2wake
2000 F-150 4.2L V-6
I had a tune up when the service engine light came on about 6 months ago. Replaced spark plugs (motorcraft) and cables. Ran a little better, but the problem still poked out every now and then. Oh, and the service engine light hans't come on since then.
Now it is worse than ever. Miss and shakes at idle speed and up to 2,000 RPM's. Hooked up to a reader yesterday and it read a cylinder 1 misfire. Checked the plug and cable on cylinder one, and it was fine. Went back and hooked up the reader and got NO reading. NOTHING. But it's still missing. Any suggestions?? Anyone had this problem before??
Your help is greatly appreciated!!!
Old May 5, 2006 | 06:07 PM
please's Avatar
please
Did you check your coil.
Old May 6, 2006 | 06:06 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome surf2 to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old May 6, 2006 | 12:36 PM
surf2wake's Avatar
surf2wake
from what i understand the coil doesn't slowly go out.... it just goes out.
is that true, if not should i just replace the coil?
Old May 6, 2006 | 02:23 PM
please's Avatar
please
I would check it out first I said that because you said there was a misfire its just a guess. I could be wrong check to see if the resistance is even all the way across should be 0.3-1.0 ohms thats between ignitioncoil pin 4-1 coil 1 thats what my chilton book says there is more info but that should get you started . Good luck I hope this helps
mtnlovrs
General Automotive Discussion
Jan 17, 2010 01:41 PM
cwalsh540
1997 - 2003 F150
Nov 19, 2009 10:07 PM
hwtsdf350
New Member Introductions
Jul 6, 2008 02:32 PM
DGMFORD
1997 - 2003 F150
Mar 16, 2007 10:12 PM
Aerostar1
Aerostar
38
Feb 15, 2007 12:41 PM
