Battery - solenoid connection
Old May 3, 2006 | 10:34 PM
PCorn's Avatar
PCorn
I have recently "inherited" a 1966 Ford F-100 Camper Special (352-V8). It has been sitting in a garage for the past two years and I want to get it running again. It ran great two years ago - I think it just needed a new battery.
I have recently bought a new battery, battery cables and starter solenoid, but unfortunately, I have never been very mechanically inclined and I'm not sure about what gets connected where. Does anybody have access to a diagram or anything showing proper connections from the solenoid to the battery?
I apologize if this question seems a bit elementary, but I am still learning. Any help will be most appreciated.
Old May 3, 2006 | 11:10 PM
customcab66's Avatar
customcab66
I don't have a wiring diagram but on my 66 as the starter solenoid is on the fender. the big conection toward the front of the truck is the positive battery cable,the first little *** is a red wire, if the stock wires are still there. the second little *** is a brown wire. the last conection goes to the starter motor. Hope that this will help you out. Not sure what each wire is right off. went and looked at the soleniod on my truck. it is a complete stock truck with 44k on it.
Old May 4, 2006 | 03:26 AM
Torque1st's Avatar
Torque1st
Posting Legend
Any power wires go to the battery connection side. The first little stud is the solenoid coil connection. The second little stud is for the ignition coil.
You may need some washers on the large studs. Most replacement battery cables are punched for 3/8" Chevy studs and a loose fit at that. Ford uses 5/16" studs which makes the cables fit badly and not make a good connection. Use silicone dielectric grease on the connections also.
Old May 4, 2006 | 08:05 AM
PROSTOCK's Avatar
PROSTOCK
If you have an ammeter in the dash, it will be a little more complicated, but not much.
Old May 8, 2006 | 06:10 PM
PCorn's Avatar
PCorn
Thanks for all of your help with the battery/solenoid. I've been driving around for the past two days and she's running great - except for the radiator - it seems to get extremely hot after driving for a while, but it doesn't seem to be overheating. Also, the temperature gauge doesn't work so I don't know if it's too hot or if this is normal. Any ideas?
Old May 8, 2006 | 06:47 PM
ol yeller's Avatar
ol yeller
Change the thermostat. It's at the end of the top radiator hose. Inside the piece the hose hooks to. 2 bolts hold it on.
tjdad62
Feb 2, 2015 12:20 AM
marsh rat
Oct 19, 2014 09:29 PM
cityjack
Feb 9, 2014 08:49 PM
Rich1953ard
Apr 28, 2013 10:34 AM
Tyler Rowe
13
Mar 8, 2013 04:35 AM
