exhaust manifold?
Old May 7, 2006 | 08:58 PM
redwood06's Avatar
redwood06
exhaust manifold?
I need to locate an exhaust manifold for my 65 f100, the problem is that my truck is registered as a 65 but has the 223 in it. If im not mistaken i think the 65 came with the 240. Regardless, all the part magazines ive looked through dont list the exhaust manifold for the 223 only the 240. Are some of the parts for the 240 and the 223 interchangable or am i just retarded. And is there an easy way to identify which engine i have.
Also any help on where to find a linkage repair kit would be greatly appreciated.
Old May 7, 2006 | 11:12 PM
FordBoypete's Avatar
FordBoypete
Question
1st of all. . . .WELCOME to FTE
Post the serial number & info on your data plate. We can tell you the engine you should have if the truck is an OEM Stock vehicle.
If you know you have a 223 CID then get a manifold for the engine rather than the year of truck it's in. The year it's registered as is the result of some governmental notion and does not have anything to do with anything that matters except your tag and their $$$$.
My truck's registered as a 66. It has a 460 CID engine, 79 - F-150 chassis & lots of other things having nothing to do with year it's registered as either. . .
What linkage are you talking about ?
FBp
Old May 8, 2006 | 10:35 AM
nictalope's Avatar
nictalope
exhaust manifold
check clifford performance.. nice exhaust setup for the 223, thinking about buying it myself to replace the stock on my 223. Besides that a junkyard or used parts place will give you a hand. I have a Ford truck parts guy here in CO that probably has a few sitting around.
Old May 8, 2006 | 03:26 PM
drof46's Avatar
drof46
As stated above:
http://cliffordperformance.net/Merch...egory_Code=F21
have fun.
Old May 8, 2006 | 07:25 PM
R Pope's Avatar
R Pope
Quickest way to tell a 223 is the valve cover. Its held down by two bolts in the middle. A 240 uses bolts out around the rim.
brider
16
Feb 26, 2022 12:12 PM
99hosss
Dec 26, 2012 02:48 PM
vntgtrk
Oct 7, 2012 12:42 PM
vinnieferg
15
Dec 25, 2011 06:32 AM
dgpruitt
Jul 20, 2005 11:10 PM
