Solenoid wiring ???
Old Oct 15, 2014 | 08:05 PM
marsh rat's Avatar
marsh rat
Solenoid wiring ???
I recently bought a 1973 f100. Has 302 with auto transmission. It sat for over two years. Replaced the battery. The solenoid looks new. It has two wires on the battery side plus the lead from battery. One wire on starter side going to starter. There are no wires on the front two terminals just a jumper connecting the two. When I try to connect the battery terminals I get a big spark and the starter engages. I tried unplugging the key switch no difference. Is it wired correctly? I looked at wiring diagrams and some are wired this way. Bad solenoid??
Old Oct 15, 2014 | 08:16 PM
HIO Silver's Avatar
HIO Silver
"Some are wired this way"? WTF?
'Not wired correctly.. remove the jumper from the two lil terminals. What effin idiot did that?? Nonetheless...
Refer to the image below. Look for for a brown wire and a red wire with a blue trace.
Connect the brown wire to the rear I terminal (ignition-on signal) and the red/blue wire to the front S terminal (starter-on signal). Attempt to start using ignition switch.
Last edited by HIO Silver; Oct 15, 2014 at 08:24 PM. Reason: reversed the wires in my head...
mikeo0o0o0's Avatar
mikeo0o0o0
Are you saying the "S" and "I" terminals (the small ones) have a jumper wire between them? If so, get rid of it.
The "S" terminal is the wire from the switch to engage the starter. The "I" terminal is the 12v hot to the ignition.
Old Oct 15, 2014 | 08:40 PM
marsh rat's Avatar
marsh rat
Thanks. Yes the "S" and "I" terminals have a jumper between them. Thanks for the diagram. Makes more sense why the problem. The PO had it wired this way for some reason. Thanks again!!
Old Oct 19, 2014 | 09:29 PM
marsh rat's Avatar
marsh rat
Got engine started today. Thanks for the help
alexjp91
Nov 19, 2007 10:49 PM
nahtanfunk
Apr 15, 2007 01:58 PM
Highguy
Electrical Systems/Wiring
Dec 27, 2004 08:56 AM
fordgirl78
15
Feb 27, 2004 10:24 PM
idealtrucks
Mar 5, 2003 08:52 PM
