whitch transfer case do I have?
Old May 2, 2006 | 04:44 PM
F250FarmBoy's Avatar
F250FarmBoy
Hey,
How do I know which transfer case I have in my '89 F-250 5-speed? Also, What transmission do I have on the same truck? The tranny code on the door sticker is W (or was I reading it backwards & it should be M???)
Please help.
Old May 2, 2006 | 05:02 PM
Dungeon_Master's Avatar
Dungeon_Master
I have the code for the tranny it if was an auto M = 5 speed manual overdrive and
W = Auto C-5. Since it has a bell housing I would easily say it's an M. Sorry I don't have any information on the bell housing.
Old May 2, 2006 | 05:23 PM
1975Ford's Avatar
1975Ford
transfer case should have a tag on t-case, it will be either a Borg and Warner (BW) 1345 or BW 1356.
Transmission tag code should start with E87A or E89A and will be located on tranmission, Get code off transmission and I can tell you what transmission you have.
buck
Old May 2, 2006 | 09:01 PM
F250FarmBoy
Well dungeon master, it's a 5-speed overdrive so it must be "M". Ford didn't put the NP transfer case in there trucks in the late '80s? O well, BW should be a good transfer case.
Old May 3, 2006 | 08:37 AM
1975Ford's Avatar
1975Ford
BW is a good transfer case. Change the fluids in the transmission and transfer case regularly with Mecron Transmission oil. BW 1345 (6.5 pints) and BW 1356 (4 pints).
Mazda 5 speed transmission (7.6 pints) and ZF 5 spd transmission (6.8 pints). Here a picture of a Mazda 5 speed https://www.ford-trucks.com/user_gal...102786&width=0
buck
Old May 23, 2006 | 08:17 PM
F250FarmBoy
Is my tranny a ZF or a Mazda? How can I tell, should it say on it?
Thanks.
Old May 24, 2006 | 09:19 AM
1975Ford's Avatar
1975Ford
Match http://www.motivegear.com/tech_info/...nny_guide.html
buck
Old May 24, 2006 | 02:12 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Sorry if Im hijacking your thread...but I didnt think another thread needed to be started for the same question...
I have a 1997 F150 4x4 with the 4.6L V8 and 4R70W automatic transmission. I would also like to know what T-case I have? I havent been under the truck to look for a tag yet. And it's manually shifted with a floor lever.
Old May 24, 2006 | 03:57 PM
F250FarmBoy
Its o.k I have no problem with it.
Old May 24, 2006 | 04:23 PM
1975Ford's Avatar
1975Ford
Originally Posted by ATC Crazy
I have a 1997 F150 4x4 with the 4.6L V8 and 4R70W automatic transmission .... T-case I have?
It should have a Borg Warner 1356 Transfer Case. It should have a round tag with red lettering mounted on the transfer case with the model number, double check the model number on tag. The transfer case uses Mecron fluid.
whiskeyrichard
Mar 5, 2022 10:34 AM
84-250
Jan 25, 2019 06:58 AM
Zombieblaster
Mar 14, 2017 11:00 AM
SVTDriver97
16
Jun 27, 2014 08:56 PM
steve604
Mar 10, 2008 06:16 PM
