Modular V10 (6.8l)
Tranny ?.
Old May 2, 2006 | 01:03 AM
1badSD's Avatar
1badSD
Unhappy Tranny ?.
I recently replaced my radiator, and with removing the old one all the tranny fluid leaked out. So I thought it would be the perfect time to replace the tranny filter and fill it up with fresh fluid. My problem is that now the truck is running funny. It's idling rough, struggles to stay on when I put it in reverse or dies, and sometimes dies when I come to a stop. Then I also noticed that after I shut the truck off that there is a buzzing sound coming from the tranny pan and buzzes for about a minute. Any idea what went wrong when all I did was replace the radiator and the tranny filter and fluid. Any help or ideas. Thanks in advance.
Old May 2, 2006 | 01:27 PM
biz4two's Avatar
biz4two
What year is your SD? Any other specs you can share?
If you have the 4R100 trans, then are you certain you installed the filter correctly? Also, did you make sure and purge the tranny lines of all the air?
Get back with that info...and I am sure more will chime in.
biz
_______________________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
Old May 2, 2006 | 02:19 PM
Casey's Avatar
Casey
Low fluid or an incorrectly installed filter can do that.
Any line that has air in it will purge itself in the first couple seconds after the engine starts. There is nothing special that you could do to purge the lines.
Old May 2, 2006 | 03:13 PM
1badSD's Avatar
1badSD
I have an 2001 F-250 CC, auto, 5.5" fabtech lift, BBK TB, K&N FIPK.
Old May 2, 2006 | 09:20 PM
captchas's Avatar
captchas
Guest
get it warm and check your level in park or nut. it most be between the marks when warm. run it into drive and reverse a few times and recheck in p or n.
which filter did you change the in line or the one inside the pan?. and did you use the correct fuild
Old May 3, 2006 | 07:01 PM
1badSD's Avatar
1badSD
I change the filter in the pan and refilled it with mercon
Old May 3, 2006 | 10:10 PM
captchas's Avatar
captchas
Guest
those sticks are very hard to read so you may be low from reading the tubes wet side
fgadsden75
Nov 15, 2016 06:57 PM
tyler.dunn94
Oct 11, 2016 10:59 AM
Lariat86
Mar 24, 2016 02:44 PM
F250_
22
Nov 24, 2011 07:08 PM
