Vacuum modulater hose
Old Mar 24, 2016 | 12:21 PM
Lariat86's Avatar
Lariat86
Im new to the site. Ive got a question. Ive got an 86 f250 with a 460 and c6 tranny. Every time i start the truck the hose on the vacuum modulater pops off. Both the hose and modulater have tranny fluid on them. Once i put the hose back if the engine is cold it surges and dies if it worm the hose still pops off when started but when replaced it idols fine and shifts fine. Any ideas as to where the back pressure is coming from that is popping off the hose would be greatly appreciated.
Old Mar 24, 2016 | 12:58 PM
1986F150six's Avatar
1986F150six
Welcome to the forum! The modulator need replacing. It is leaking internally and the transmission fluid is sucked towards the carburetor. The fluid causes the vacuum hose to soften and swell, so it comes off the vacuum port. The loose hose causes a vacuum leak which causes the engine to run poorly.
Old Mar 24, 2016 | 01:34 PM
Gary Lewis's Avatar
Gary Lewis
Yep, on all counts - welcome to the forum and replace the modulator.
Old Mar 24, 2016 | 02:01 PM
Lariat86's Avatar
Lariat86
Thank you for the input will be giving that a try.
Old Mar 24, 2016 | 02:44 PM
1986F150six
If you can, take yours out and carry it with you to the parts house. Some of them have a colored ring for identification purposes.
Grey Beard
16
Mar 7, 2018 03:27 PM
400inatruck
Sep 2, 2012 09:05 PM
danlee
Aug 18, 2011 02:30 PM
F150'89
General Automotive Discussion
Oct 31, 2004 06:19 PM
