95 Eddie B Explorer shift problem then OD light flashes
Hi guys.
My 95 Eddie Bauer Explorer is having a problem shifting, it's automatic.. It will shift if I gun it from 1st to 2nd and let off the pedal to help it. Then my OD light starts flashing. I have to help it shift after that by releasing the gas pedal. Then my speedometer goes out.If I'm correct the speed sensor is the problem for the Speedo . But whats the problem with the shift? Do I need to rebuild? I could use your wisdom and advice again!~ Thanks Gabriel C.
I pulled the codes today and found many things I think!
TOT Trans Oil Signal Volt to high
SOS Speedometer Sensor
HEGO Heated Exhuast Gas Sensor Voltage To Low
Engine coolant temp low voltage
Fuel Pump open circuit connect to battery
Fuel pump ECA assembly motor ground Can you help me with any locations and info about the subjects at hand! I'd really appreciate it.
JR270
03-07-2006 04:27 PM
bren7176
02-19-2006 11:02 PM
