which carb on 466 cid?
Old Apr 30, 2006 | 02:22 PM
lincoln's Avatar
lincoln
hello,
got a question about carb size,
my engine is a 466 (.30 over) with flat top pistons,
c8 heads, headers, performer intake, comp cam powermax cam, electric waterpump etc, but wich carb should i run?
i`m thinking of a demon 850 vac. sec. w/annular or is this to big?
thanks
Old Apr 30, 2006 | 03:36 PM
FE Man's Avatar
FE Man
It all depends on what you are going to use it for I guess. I would say a 750 would work good but a 850 would work well to. All depends on your intended purpose for the vehicle.
Old Apr 30, 2006 | 04:19 PM
lincoln's Avatar
lincoln
i`m gonna use it on the street and maybe strip.
thanks
Old Apr 30, 2006 | 05:00 PM
Bear 45/70's Avatar
Bear 45/70
Before you can determine carb suze need to know acouple of things. Is it stock except for over bore and how many revs are you going to turn it to? How much cam does the engine have? Unless it is a race motor or a Hi-Po street motor and 850 is way to much and will hurt preformance and fuel economy. They come stock with a 600 because anything past 4500 and the cam runs out of go and the engine needs no more carb. There is a formula to figure what size carb you need.
CFM= RPM X CID Divided by 3456
Old May 1, 2006 | 01:40 AM
Pre'80's Avatar
Pre'80
Actually the formula is CFM= RPM times CID divided by 3456 times (VE% divided by 100)
Example: 5000 X 466 / 3456 X .85 = 573.06134259259259259259....CFM. Generally a stock motors VE is in the 78-88 VE range
Old May 1, 2006 | 04:02 AM
Bear 45/70's Avatar
Bear 45/70
The one I gave works for a street motor just fine and 99.9% of the characters out there always over estimate how efficient their engines are and I figure if you keep it simple, then their egos can't get carried away. I however totally agree with you numbers.
Old May 5, 2006 | 02:59 AM
jamies460's Avatar
jamies460
Hello, i run a 670cfm Holley street avenger carb on my 460ci along with the Edelbrock performer RPM manifold, my 460ci is 40 thou over, it performs really well. unless you have some work done to your engine a 670cfm or 750cfm vacume secondary should be fine, Jamie. Australia.
Old May 5, 2006 | 10:39 AM
lincoln's Avatar
lincoln
thanks for the reply`so far
ford4x4s
General Diesel Discussion
22
Nov 4, 2016 05:22 PM
ATC Crazy
Jul 18, 2014 05:24 PM
Hawk180
23
Mar 23, 2014 08:31 PM
ramseygus
Dec 3, 2010 12:15 PM
master_mechanic
Offroad & 4x4
15
Oct 25, 2009 01:55 AM
