Offroad & 4x4
Update
Old May 4, 2006 | 09:55 AM
RawPower's Avatar
RawPower
Wasnt my ida though... it was either Ivan's or Green's
Yokes size sorry. Im putting on some new u-joints... didnt know what to get or what to build the shafts for on that end.
Yeah a coupling nut would work fine, as long as it was raw and not coated or anything like that cwaziness...
Chris im gonna check out pirate and that vendor you mentioned, thanks
Old May 4, 2006 | 10:05 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
spend the money and buy the proper inserts with jam nuts...i would not trust a coupling nut on steering parts etc, especially for highway duty...
measure the yokes for the size of the ujoint cross....ie the end of the cap to the end of the cap....likely they are 3 1/2" (1310 sized) but possible 1330 37/8" , could be a mix of both, you never know
is that what your looking for?
Old May 4, 2006 | 10:19 AM
RawPower's Avatar
RawPower
all three yokes are the same size, but ill measure to make sure.
I will also get weldable rod ends, but the REAL question is:
Do I get chebby TRE's or get some good RE's?
Problem is the TRE's have a 1" dia thread area, and the only RE's I can find that go into the only weldable inserts are 1" and have a 1" bore in the heim. Does that make sense? So I would have to ream out my current TRE holes for the chebbies, but what would I do to get a heim that screws into the 1"-14 rod end insert?
polyperformance only sells the 1" bore size, wich would probably be a little too much reaming on my axle... hahaha
Old May 4, 2006 | 10:33 AM
KubotaOrange76
get the chevy tre's....you can pcik them up at any locak prts house instead of having to order....and they are greasable etc...
im confused what your asking in those last two paragrpahs..sorry, but it may be because im about to go take an exam and my mind is elswhere
Old May 4, 2006 | 11:26 AM
fishmanndotcom's Avatar
fishmanndotcom
do the chevy TRE's! they are massive and will last longer than heims.
you can find those weld in inserts on ebay often times for cheappppo!
-cutts-
Old May 4, 2006 | 12:41 PM
Thomsen's Avatar
Thomsen
Dang you've got some ***** to cut up that pickup, awesome. Looks good, cant wait to see the tires mounted.
Old May 4, 2006 | 01:20 PM
RawPower's Avatar
RawPower
Haha thanks. Well long story short, it is my first truck and my dad graceously bought it for me. I can't be more thankful that I didnt have to buy my first car. However, shortly after buying it, the engine crapped out on me bc it cavitated. He kinda felt bad for picking out a truck that did that so quickly. So that led to me rebuilding the engine and then using his guilt to allowing me to modify it with MY OWN money from then on, as long as they were small mods., like pyro/boost/water guages, exhaust... whatever. So then he comes home and sees the back half of the bed on the ground... WHOA. Had to do a little smooth talking to keep him relatively cool.
Anyways, thanks.
Aight TRE's it is, but now for the rims... do I sell the NIB ons I have that are excessively pimpin for an ORV and get DB's or keep the current ones?
Old May 4, 2006 | 01:48 PM
KubotaOrange76
well how much $$ would u lose if you sold them?? take that into account.....but if i were you i would at least get some sort of steel wheel
call stazworks and usa6x6, along with mrw....get some prices and stuff
if you plan to wheel it i would hate to ruin those $$ bling wheels
Old May 4, 2006 | 01:56 PM
RawPower's Avatar
RawPower
They were cheap compared to other 20" rims... only $180 apiece. I dont know if they are cast or forged, is there any way to tell by looking at them?
I think Ill get the TRE's here, unless you or cutts knows of a better place:
http://www.partsmikeparts.com/
Now I have to find a weldable tube insert that is for a 1.250" ID tube with threads for 1"-18tpi stuff, ie- the 1 ton TRE's. I found some that are 1"-14tpi on www.polyperformance.com , but no 18tpi. Perhaps a call is in order.
First I'll check out some other vendors on Pira___te...
Edit: Who is MRW?
Old May 4, 2006 | 05:06 PM
KubotaOrange76
the chevy es2026 and 2027 ends u used were 7/8 threads...the inserts fit into 1" tube i had to drill the ends of my 1.5" 3/8 wall tube out
sounds like those wheels are cast...still i would see if you can get some decent $$ for them, if so at least get a plain steel wheel
i cant tell you how many times i cussed having those weak **** cast aluminum wheels on my junk....ask cutts about our last trip to grayrock...you have to constantly watch banging them into something because they crack and break, they dont bend like forged aluminum and steel
Old May 4, 2006 | 06:32 PM
RawPower's Avatar
RawPower
My tubing has a 1.25" ID, So I have to find a different insert
Old May 4, 2006 | 07:26 PM
proeliator's Avatar
proeliator
I'm glad you are using the right inserts. If poly doesn't have them one of the vendors over there will. I've made my own inserts by taking pipe that fit inside perfectly and tapping it but with inserts as cheap and available as they are its not worth it these days. The chevy tre's are the way to go, I did. Ivan has the part numbers in his gallery, I wonder if they are the same ones as ko's.
94 XLT White/ Silver 302
1978 - 1996 Big Bronco
May 5, 2006 10:29 PM
RawPower
Offroad & 4x4
35
Apr 4, 2006 02:03 PM
mustange70
Offroad & 4x4
Sep 13, 2005 04:31 PM
RawPower
Offroad & 4x4
31
Aug 14, 2005 10:39 AM
monsterbaby
Offroad & 4x4
17
May 14, 2005 06:19 PM
