here's the run that i broke the axles and u-joint and everything on, if you listen carefully in the last 3-4seconds of the vid you can hear the motor pick up a couple hundred rpm's from the above parts letting go:
Up to that point of the day that was the long run, and with the exception of the guys runing 40"+ tires held up till they removed some mud from the pit.
And this one here is of my winning run 2 weeks pior to the above event (oh yeah you can hear my fan club in that one ):
