rear end gears?
Old Apr 27, 2006 | 07:09 PM
ole yeller 1978's Avatar
ole yeller 1978
rear end gears?
If I turn my rear wheels 5 complete turns and my driveshaft turns 7 complete turns what gears do I have in my rear end?
Thanks
Jeff
Old Apr 27, 2006 | 07:46 PM
ford390gashog's Avatar
ford390gashog
well with that info i can't tell you. you want to turn the wheel only enough rotations to make the drive shaft spin once. if the tire takes 3.5 turns to make one full turn of the driveshaft then you have a 3.54 rear gear.
Old Apr 27, 2006 | 08:05 PM
Torque1st's Avatar
Torque1st
Posting Legend
Check the Read First: FAQ thread at the top of the 73-9 forum for rear axle ratio and data tag decoder info.
Old Apr 27, 2006 | 08:42 PM
Mil1ion's Avatar
Mil1ion
Quote: wheel 5 times and DS 7 times.
1.40:1
Quote #2:
__________________
Better try that again
If the wheels turn once and the drive shaft turns 3.5 times you have 3.50 gears.
The best way is to turn the wheels 10 times and count the revs of the DS.
What code is stamped on your data plate ?
Old May 1, 2006 | 09:21 PM
trinogt's Avatar
trinogt
This all sounds odd to me. My method sounds strange and doesn't sound like it should work, but it does.
Jack up one wheel, put trans in neutral. Turn wheel two full turns and count driveshaft rotations. Those rotations are your ratio. (two and three quarter turns is 2.75, three and a half turns is 3.50, etc)
Trust me, it worked everytime I tried it, on several different vehicle! You will have to jack both wheels if it is a locking diff.: Limited slip may work ok.
Also, it is nice to put a reference mark (like chalk, or a fridge magnet) on the driveshaft to keep track of turns.
Mark
Old May 1, 2006 | 09:59 PM
califasbob's Avatar
califasbob
Your method did sound strange until I thought about it, trino. With an open diff, one wheel stationary with the other turning would require two rotations to equal one rotation with both wheels turning, right? So your options are to jack up both wheels, have a helper turn the other wheel with you (or have a locking diff) and count driveshaft rotations to wheel rotations OR just use one wheel and double your wheel rotations to make the driveshaft do the same thing.
If you did your 5:7 test with only one wheel off the ground, that would be equivalent to 2.5 ring gear rotations to 7 pinion rotations or 2.8:1 (double Million's correctly calculated 1.4:1), which I would assume is a 2.75:1 rear end. Does your truck cruise at low RPM's on the freeway? Have a hard time getting a trailer to break the moment of inertia? If so, your '78 is like mine was originally gear-wise. As long as your ski boat doesn't drag that old Ford into the lake when you try to pull it up the boat ramp and gas is $3/gallon, leave it!
Hope this helps you, I learned a new trick from trinogt!
Bob
Old May 1, 2006 | 10:04 PM
Torque1st's Avatar
Torque1st
Posting Legend
Guys, -use the method listed in the FAQ thread, it is much more accurate.
Old May 1, 2006 | 11:06 PM
trinogt's Avatar
trinogt
I will stick with my method... easy to remember, and doesn't require coming back to the computer for an FAQ when I am at the junkyard haha
Also, I NEVER rely on door codes, as ratios can be changed like underwear throughout the life of a truck, depending on what each user needs out of his/her truck. Axle tags are also gone 90% of the time, likely from junkyard scroungers snapping them off to read easier. And, who's gonna pull the driveshaft and carrier just to count teeth?
CBob, that makes sense, bud! Now, if I can remember the reasoning for the rest of my life! lol Thanks!
Mark
Old May 2, 2006 | 01:36 AM
Mil1ion's Avatar
Mil1ion
Mark, I used to suggest your way because I found it works .....Until I was told a few times on here that it was the wrong way to do it.
I haven;t been under the truck since to try again
Old May 2, 2006 | 01:49 AM
Torque1st's Avatar
Torque1st
Posting Legend
The two turn method is not accurate enuf to tell the difference between say a 3.33 and a 3.50 etc with any degree of certainty. I have used it for a quick estimate but not for identification tho.
Old May 3, 2006 | 05:54 PM
trinogt's Avatar
trinogt
I have never come across a 3.33:1 ratio anyway... And if I did, JACKPOT! Between a 3.25 and a 3.50? Nice. And YES, a 'two-turn method' WILL differentiate between a 3.25 and a 3.50, the 'more common' Ford truck ratios.
Mark
jghjunk
1978 - 1996 Big Bronco
Aug 15, 2011 11:55 AM
jeff8362000
Nov 19, 2009 12:44 AM
station207
Feb 17, 2008 06:52 PM
jgrm2
2004 - 2008 F150
Oct 10, 2006 10:27 AM
mrblue01
Feb 28, 2003 09:58 AM
