Rear End "Clunking" While Reversing
Old Oct 3, 2006 | 10:34 AM
jgrm2's Avatar
jgrm2
While reversing - especially with the wheel turned as if backing out of a parking spot - I am getting a series of clunks or pops from the rear end. I did a search of the forum, TSBs, and recalls and did not find anything. I appreciate any ideas on what to inspect.
By the way, my truck is stock and equipped with the non-limited slip differential.
Thanks,
Jeff
Old Oct 3, 2006 | 02:40 PM
jgrm2's Avatar
jgrm2
Ooops, I just noticed my signature line listed my old truck, which was a 2001 model. My question pertains to my 2005 F-150 SuperCab. Sorry if that deterred any responses.
Thanks again,
Jeff
Old Oct 3, 2006 | 03:23 PM
ford9c's Avatar
ford9c
I know fords been having issues with the limited slip diffs making noise, binding, and so on. Havn't heard that yet with the open diffs. Your probably just lucky. I would get it in to the dealer soon to get everything checked out, hopefully under warranty. Suspension noises can sometimes travel along the frame and what you think is the diff could be something else. Also you want to make sure nothing is comming loose and making the noise.
Old Oct 3, 2006 | 03:32 PM
214kfd's Avatar
214kfd
Check the drive line really good. I had both bolts come out off the brace that holds the drive shaft.
Old Oct 4, 2006 | 07:42 AM
4DOORSR's Avatar
4DOORSR
I get a binding feeling when I accelerate through a turn from a stop. Almost feels like rubbing. Happens more often when I have a load in the box.
Old Oct 8, 2006 | 11:51 PM
BLariat's Avatar
BLariat
4DOORSR, have you had the fluid in your differential replaced? Is your axle limited slip? I had this problem when they changed the fluid in my LS axle and didn't put the right lubricant in it.
Old Oct 10, 2006 | 08:25 AM
4DOORSR's Avatar
4DOORSR
No, I haven't changed the fluid yet. It is a limited slip axle. I asked the dealer and he said not to touch the rear end until I have over 100,000km.
Old Oct 10, 2006 | 10:10 AM
BLariat's Avatar
BLariat
There is also a TSB that outlines this problem and basically says that you need new clutch packs and there is a new fluid for the differential. The TSB number is 06-4-4.
Old Oct 10, 2006 | 10:27 AM
Cavtrooper06's Avatar
Cavtrooper06
Here's the link to that TSB:
https://www.ford-trucks.com/tsb/full...php?tsb=06-4-4
smithrock
May 8, 2012 06:17 PM
MDSuperDuty
Dec 5, 2011 07:37 AM
redranger1
2004 - 2008 F150
Oct 9, 2011 06:35 PM
drewskeez
Mar 24, 2011 08:35 PM
greybullit
1978 - 1996 Big Bronco
31
Feb 10, 2006 08:45 PM
