E150 front coil spring sources
If the stock springs need refreshed as Maples01 says look into using the same ratings as an E-250. Shocks AND stabilizer bars both front AND rear do a lot to slightly improve handling characteristics.
There are already quite a few threads dealing with "handling" and most have come to know the E-Series is NOT chassis that's extremely difficult to handle like a sports car. I stopped chasing this non-problem after quite a bit of spent money with minimal improvements. Hellwig sway bars, Bilstein shocks, urethane bushings, Michelin LTX tires---minimal return on investment.
I have to find someone to install my springs, shops here seem ignorant, want to tell me the danger of struts, that gets you crossed off my competence list, not knowing what is on a vehicle as you claim to be a mechanic, and beware everything has Chinese copies which some may be equal, most are inferior, they can't even get camshaft tempering right as of late, needless to say the weight bearing coils and leaves will be detrimental if not properly heat treated. Ford vans are I-beams, designed and built for durability as Ford was heavy in the commercial market, they are not for comfort, I've owned Fords with them since I could drive, they hold up the longest of any other vehicle without shop attention, but they can not be made to ride like the others, shops that know them and can properly adjust them are getting rare, I was shocked to find one here, near me, all the classics are filling the lot.
1988 E150 high top conversion w/5.0 and AOD transmission.
Around 6 years ago I thought I would rebuild my suspension. Not because it was sagging but because the van was nearly 30 years old and I wanted it to last another 30 without having to be worked on.
I went to Moog's website and selected the springs that their web site said were for my van. Since they didn't sell direct I wound up buying the coil springs through Wal-Mart who happened to have the cheapest price and I could pick up locally and save shipping.
Ford engineers the suspension to be in alignment and a certain ride height from the factory. As you drive and sway from side to side, the I-Beams are always moving but the front end stays in alignment. One place where you run into issues is when you change the coil spring to a different spec from what Ford originally used.
The springs that I bought DID NOT not work on my van as they were a bit taller then the originals. Being taller caused the I-beams to tilt down farther then they should and the wheels were in a positive camber that you could see looking directly at the front of the van. I was told that they would settle down over time. I went on several trips to the mountains with 8 people and full.y loaded down with camping gear where we drove on gravel roads for 20 to 40 miles each time. The springs did not settle and my new tires were starting to wear on the outside. To fix the issue I reinstalled the old springs which to this day are still within spec at alignments.
Walmart would not take the springs back claiming that I had to deal through Moog and Moog said they couldn't do anything for me so they lay on the floor off in the corner of the shop. Since I have never bought through Walmart again and though Moog builds good parts, I avoid them when ever possible. As with all purchases now, I ,make sure of the return policy!
I was surprised that Moog would not take care of this issue as even talking whit their tech guy, he said the springs I selected were what his site showed to be correct though there was another with one lower rating that I could try but they wouldn't exchange the springs.
As you can see from the pic below, on the left, C= non movable spring retainer. B is the axle beam and C the spring. E supports the axle pivot. If you were to lengthen the factory spring, A, the axle would be pushed down farther then it should be and you would go into positive camber. To keep the geometry then you would also have to lengthen E, the picot bracket. On my 88, if I remember correctly, the pivot bushings fasten directly into a cross-member and are not mounted to brackets like in the pic. But you should be able to get the idea of what I am trying to say.
Also if you find a Ford service manual for your van, it will have a section devoted to the suspension and ride height. below is a page from my 88 manual. to get a proper alignment on my van, the ride height needs to be within the specified specs. Putting heavier and taller springs on the rear would certainly through more weight towards the front end.
As to the king pin axles, ford did make a 1/4" steel plate that goes under the lower spring perch and that would normally account for mild sagging springs.
