Front Spring Swap Rv to E350
Old Nov 4, 2006 | 01:05 AM
Desert-Rat's Avatar
Desert-Rat
I'm wondering if the front coil springs from say a E350-E450 Motorhome or box van are compatable with a E350 15 pass Van? And if they have a higher spring rate and height.
I would like to address the nose dive I get when braking down sharp mountain roads and I would also like to accompolish a more stout front suspension and add 1-2 inches of ride height that is needed for off road travel.
I thought about front air bags in the springs but I would like to accompolish this with a more maintenance free approach.
Old Nov 4, 2006 | 08:56 AM
carrfamilynj's Avatar
carrfamilynj
That's a good question, I'm curious to know the answer myself. I am looking to raise the front 2" so I can get 265/75s under there.
Old Nov 4, 2006 | 03:56 PM
maples01's Avatar
maples01
I went with the air bags for inside the coils, but I was looking to over come the effects of leaning when Exiting the side on my wheelchair platform, and eleminate the premature failure of the coil on that side. The bags were rather easy to install, can be on a T together, with only one valve to refill, or seperate, for my purpose, they're seperate. I remember seeing a heavier load set of coils in a JCWhitney add, I believe the motor home is the same platform as the one ton vans.
Old Nov 17, 2006 | 11:24 AM
windsor4x4's Avatar
windsor4x4
air bags work very well,improves stability w/1 to 2" lift,in stock at most RV dealers
Old Nov 17, 2006 | 01:40 PM
MADVAN's Avatar
MADVAN
RV and Van have same spring. The biggest coil is if i remember 44 hundred lb.
What you need depends on motor package. I have 44 hundred lb with air bag at 15lbs with the 7.3 diesel. If you go with bigger spring to lift van remember that the wheel alignment starts with ride height. Go to high and you might have to start bending I-beams to get it to align.
Old Nov 17, 2006 | 05:24 PM
maples01's Avatar
maples01
The 90's van's have camber bushings, they are adjustible to a point, but depends on the factory insert, if factory is zero or negative, you can go up, but if it's already a positive, chances are it's maxed out already, requiring the beams to be modified. I installed air bags in my coils, aired to where I wanted them, but didn't wait long enough for them to settle before getting the camber adjusted. I plan to buy a camber gauge to put on my front wheels so I can adjust the air pressure till I get it set where it should be, don't want to go back in for another $80 adjustment. This is the bad on the air bags inside the coils, they alter camber when they lift the van.
twiisted71
19
Sep 27, 2015 09:01 PM
monstrs
Sep 5, 2015 04:43 PM
amosmoses
Oct 3, 2014 07:01 AM
Box on Wheels
13
Feb 9, 2014 06:45 AM
