So I'm installing the Toyota power steering box in my '56. Lots of small issues like how to hook up the shift linkage on my Flaming River tilt column shifter column. Nothing impossible, just not "bolt in and go" the way I dreamed it was to be. I've made three floor plates to get the column pointing where I want it to be.
The real question is, "How do I know when the drag link is worn out?" The one I have is most likely original or at least old and used. I see some wear marks from the spring loaded cups on both ends. And then (sorry two questions in one post!), how do I adjust the spring compression? I can't find anything about it in my factory manual. Seems to me that a poorly adjusted drag link would make the monkey more drunken on the road.
Also check the ball ends at the steering arm and the pitman arm. They get egg-shaped. The new ones I bought mic'd at .98-.99 inch. They need to be pressed in by a monster hydraulic press but you're into it so far--why not?
Just tighten them all the way and then back it out until you can get the cotterpin in. The springs are there to soften a hard hit to the tire to save the gearbox teeth. If the wear is more than a shiny spot replace the ball. A new ball comes on the conversion pitman arm and Mid Fifty sells replacement ***** for the steering arm IIRC.
Thanks for the help guys. Always good info here. The swing arm ball is fine, shiney, but no ridges. I was wondering about the wear inside the drag link where the cups and springs move back and forth. I noticed pair of marks that look like something has rocked around a pin. Will that kind of wear be a problem? Normally I assume any wear is ultimately not good, but was just wondering.
IMO, as long as the wear is not severe it shouldn't be any problem since it's not a precision fit and a low velocity joint. Replace the grease fittings with new, grease it up fully with a good wheel bearing grease and make sure the dust boots are intact. Give it a shot of grease each time you change the oil or twice a year if you drive it in the wet.
I got the ball ends from Mid Fifty. The little bit of slack in each joining area adds together for a big bunch of slop. So, that is why I replaced the ball ends. It took heat and a 25 ton press to move the ball end out of the steering arm though.
