Window Problem
Old Apr 24, 2006 | 02:31 PM
carlb's Avatar
carlb
Window Problem
Need a little help. Wife advises that she cannot get the passenger side door window to go up. It will go down, but not up. It always hs been a little slow in closing. Any help would be appreciated. I tried a search but it is broke with no relief until this weekend. Thanks. Vehicle a 2000 X Limited.
Old Apr 24, 2006 | 07:46 PM
mudman00x's Avatar
mudman00x
try spraying wd 40 in the track, sounds like the track is binding, probably should take the door apart and look inside while operating window
Old Apr 25, 2006 | 09:18 AM
carlb's Avatar
carlb
Thanks mudman00x. I will check that. Also, I was able to do the search and get a whole lot of info. Thanks all.
Old Apr 27, 2006 | 06:04 AM
Downriver Thunder's Avatar
Downriver Thunder
any updates?
Old Apr 27, 2006 | 12:42 PM
carlb's Avatar
carlb
I'll post an update when I have one. Currently I am 160 miles away from the "Wife's" X. I'll be ther this weekend and figure it out.
Old May 1, 2006 | 09:26 AM
carlb's Avatar
carlb
Troubleshooting the problem revealed that the white wire with the yellow stripe from the drivers side switch to the passenger side switch appears to be open. The motor works both ways when "hot wired" and the window mechanism moves freely. All switches work properly. I ran out of time, but I will locate the break in the wire and either splice it ir replace it. The window has always gone up slowly which may be due to the wire being pinched during manufacture. I will let you all know on the actual fix when completed. Thanks everyone for your knowledge found in a forum search.
millerm740
1997 - 2003 F150
Apr 5, 2016 09:26 PM
Skalywag
Jul 9, 2015 10:49 PM
Dave East
May 30, 2015 05:04 PM
rschleicher
Escape & Escape Hybrid
Jan 9, 2007 05:28 AM
greybullit
1978 - 1996 Big Bronco
Dec 21, 2005 12:42 PM
