1978 - 1996 Big Bronco
Rear Window
Old Dec 20, 2005 | 05:51 PM
greybullit's Avatar
greybullit
Cool Rear Window
Okay, so I know this is a NOTORIOUS problem on the broncos but my rear window on my 90 Bronco is a pain in MY rear! The problem is that it won't go down, its stuck up, which is better than the time it was stuck down in the rain. Anyway, I've replaced the motor twice and each time i did that it would work for a little bit then quit. This last time I put the window down to load a bike into the back and then once I put it up again it just stayed up! Are there any ideas to what my problem could be, faulty wiring? Bad rubber around the window? Anything at all would be a great help! Because changing that motor bites! Almost lost my hand doing it onetime too! Thanks
-James
Old Dec 20, 2005 | 06:14 PM
greystreak92's Avatar
greystreak92
There are several things that COULD be the problem. Some model years are prone to having the wiring harness between the gate and the jamb get pinched or broken wires. Not sure why, Ford may have addressed the problem sometime during the production run. There is also a safety interlock switch on the driver's side latch that unless it is engaged, will not let the window move at all... period. An older worn striker bolt, a loose latch, or misaligned latch can keep the interlock switch from engaging. Try leaning on the driver's side of the gate while running the keyswitch and see if the window will move. IF thsi does turn out to be the problem, it requires some tinkering with the latch/striker bolt alignment and or replacement of one or both of them. The interlock switch itself could well be the culprit too. Unfortunately, ALL of these things are in a location that is not easily accessible with the window up and the gate closed.
Old Dec 20, 2005 | 06:49 PM
greybullit's Avatar
greybullit
Right on, I'll definitly check those areas
Old Dec 20, 2005 | 08:39 PM
Schlump's Avatar
Schlump
When my rear window wouldn't move, (I believe mine was down in the cold and rain) it turned out it was the interlock. I confirmed this by opening the access panel and jumpering the switch. Got it working with the jumper, I was able to take the Cub Scouts camping and afterward ordered a replacement from Jeff's and replaced it.
Old Dec 21, 2005 | 09:40 AM
dwoodler's Avatar
dwoodler
Just this past summer after the 24 days of rain in New Brunsick, my rear window refused to move. After some huntin' around it ended up being the wiring connector in the bottom well of the tailgate. The spades were corroded and not conducting. I cleaned them up, added some di-electric grease and no problems since.
Woodler
Old Dec 21, 2005 | 12:42 PM
jccastl's Avatar
jccastl
Of the four broncos I have had in the last 20yrs, when there has been a window issue it has been the motor pigtail connector being loose or dirty or the wiring section from the body to the tailgate shorted. I think someone said to remove the tailgate panel and apply 12v to the motor pigtail. If it doesn't move when connected then reverse your connections. Oneway moves it up, other down. I think I have actually had to replace a motor once. Guess I have been lucky not having any locking issues.
Jim
76250_4x4
Sep 29, 2011 11:33 PM
RJH123
Oct 27, 2009 09:32 AM
96broncoXlt
Jan 20, 2007 03:58 AM
Wolfman2405
20
Sep 9, 2003 10:14 PM
55FordLover
Aug 26, 2003 08:36 PM
