Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
cleanup
Old Feb 12, 2002 | 07:11 PM
Caddy 53's Avatar
Caddy 53
cleanup
Something you might try is course saw dust or wood shaving's such as used for animal beddy is cheap to aquire and very effective for soak up of most garage liquids.--gas,oil,antifreeze, water, snow drip when you have to crawl underneath. dispose in trash or some case burnin your shop barrel stove. chuck
Old Feb 12, 2002 | 07:30 PM
orange peel's Avatar
orange peel
cleanup
another thing that helps to clean up that im sure every one knows of by now is kitty litter.
Old Feb 12, 2002 | 09:30 PM
Vampiro's Avatar
Vampiro
cleanup
what about sand for stuff like that?
Old Feb 13, 2002 | 07:20 AM
Caddy 53's Avatar
Caddy 53
cleanup
[updated:LAST EDITED ON 13-Feb-02 AT 08:21 AM (EST)] The problem w/sand is that it won't absorb liquids like saw dust .
I think Floor dry and kitty stuff is to slow but better than nothing. caddy 53
Old Feb 13, 2002 | 11:00 PM
46fordtruck's Avatar
46fordtruck
cleanup
Kitty litter and Floor Clean are clay products, meaning they are porous, which allow them to clean up spills, sand can't really absorb since it isn't porous. And that concludes today's science lesson, class dismissed...
Gary M.
46 truck-6cyl now, 302/C4 soon
46 truck-flathead 8, 4spd
47 truck-getting a 429/C6
57 Ford FL 500-4 dr-312/AT
70 Mustang fastback-351W/FMX
72 Olds Vista Cruiser-350/AT
88 Bronco II, 500,000+ mi.
Old Feb 14, 2002 | 08:51 AM
winfordr's Avatar
winfordr
cleanup
Interestinly I have just recently tried using sawdust. I have used the asorbent stuff you buy, but it is so dusty, if your knees brush the floor where it has been, it gets all over them.
In contrast, I had just cut up some Bois d' arc (bodark) trees an had a big pile of its sawdust. In contrast to oak or pine, this sawdust is very fine, due to the extreme hardness of the wood. I decided to try it on an oil spill and it worked great. Afterwards, I vacuumed it up and there was no dust or oil left.
Winford
Old Feb 14, 2002 | 11:27 AM
Brownie's Avatar
Brownie
cleanup
I use good ole dry dirt. It seams to work pretty good. It's also very cheap.
Old Feb 14, 2002 | 08:36 PM
76RangerXLT's Avatar
76RangerXLT
cleanup
the floor absorbant we use doesn't leave dust, and we don't have to clean it up afterwards. it works good. Hi+Dri
Old Feb 15, 2002 | 10:44 PM
Greywolf's Avatar
Greywolf
cleanup
Old Jun 25, 2005 | 01:58 AM
afinepoint's Avatar
afinepoint
I second the sawdust method. Occassional cutting projects fill the shop vac. I dip from it when needed.
As a note of caution fine sawdust is not flammable it is explosive so be careful near flame, sparks or hot exhaust systems.
Reg
mgermany
2009 - 2014 F150
34
Jun 22, 2009 09:00 PM
Buckarcher
Jan 15, 2003 09:42 PM
GMFDBob
May 8, 2002 12:25 AM
Kenny
16
Nov 29, 2001 10:18 PM
dinosaurfan
Jul 17, 2001 12:57 PM
