2.9 Mpg
Old Apr 24, 2006 | 09:37 AM
big blue 95's Avatar
big blue 95
2.9 Mpg
Im looking at getting a 1990 supercab shortbox ranger as a back and forth beater. Its a 5 speed manual not sure on the ratio but what kind of mileage will it get out of it? i have my f150 for hauling heavy loads and i drive with a light foot.
Old Apr 25, 2006 | 08:50 AM
TigerDan's Avatar
TigerDan
Mine's an '89 Supercab formerly 2.9. I had the A4ld auto with non-functioning O/D and a few problems, usually got around 14-17 combined. I also tend to be a bit of a leadfoot, so that doesn't help.
A five-speed in good shape should get more like 18-21, possibly a little higher for straight highway driving.
Old Apr 25, 2006 | 11:18 AM
87 XLT's Avatar
87 XLT
After swapping everything to synthetic lube (engine/trans/diff)
my 87/2.9/5 speed/2WD/3.45 gears gets about 26 MPG cruising at 70 MPH.
The syn fluids bumped it up about 1 MPG.
Old Apr 25, 2006 | 03:21 PM
fyre82's Avatar
fyre82
My reman 2.9 in the '88 4x4 5 speed gets consistently about 17mpg, but I have no speedo correction so not sure if it is close to accurate.
Old Apr 25, 2006 | 07:48 PM
big blue 95
Hopefully i could get a little bit better than 17 mpg cause i get that with my f150 with the 4.9 and a five speed. Well at least the ranger im going to buy is gonna be really cheap for the shape its in.
Old Apr 27, 2006 | 08:50 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
A few years ago I had an 88, same as what you are looking at but I don't know what the axel ratio was, and I would get pretty consistently low 20's mpg. On long trips where the speeds were 50-60mph I could get 25-26 mpg. I would check the level of the antifreeze because 2.9's like to crack heads and check the hydralic clutch resevior and look for leaks around bottom of the bell housing. if the slave cylinder is bad, it is kind of a pain to change because you need to pull the transmission to get at it. If the price is right and mileage good, I think it would make a good truck.
Old Apr 27, 2006 | 09:13 AM
big blue 95
The only issues that it has is a little tick while its running and one of the valve covers leaks just a touch of oil. The AC doesnt work anyway so im gonna take that belt off and the coolant was still full even though it sat for 2 years before my friend got it.
Old Apr 27, 2006 | 09:22 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
my 88 had a tick also but ran good. taking the ac out of the loop will help with mileage a little also.
Old Apr 29, 2006 | 03:35 PM
bigwillie's Avatar
bigwillie
In my 88 bronco II with a 2.9L i got anywhere from 16mpg (making a lot of short trips) to 25mpg (on a long highway run) It usually averaged around 19-21mpg. Oh yeah, check every part of the cooling system, before you decide to buy it, my 2.9L eventually died of cracked heads.
Old May 1, 2006 | 10:23 AM
big blue 95
Thanks for the advice now this rain needs to quit so i can get outside and get a good look at it.
mxer0022
6.7L Power Stroke Diesel
May 25, 2017 12:34 AM
Norma stitz
Nov 8, 2016 01:16 PM
IHCubCadet
General Automotive Discussion
Jul 23, 2016 01:42 PM
02GrayPowerStroke
1997 - 2003 F150
17
Aug 12, 2015 08:50 AM
scottddove
Jul 11, 2006 11:56 AM
