92 4.0 v6
Old Apr 18, 2006 | 03:35 PM
Tommy1956's Avatar
Tommy1956
Question 92 4.0 v6
Hi I have a few questions.
1. What makes a check engine light come on and go off and not give a code?
It only comes on occasionally.
2. What makes an engine sound like it has a dead miss once about every 5 miles? This is when the check engine light comes on. It goes off after about another half mile.
3. When I kill the engine the radiator empties into the resorvor and flattens the top radiator hose.
Thanks. I hope that was enough info.
Old Apr 18, 2006 | 04:54 PM
Franklin2's Avatar
Franklin2
The computer does have a code. It will be a memory code, not a hard code.
Here's a description. http://www.troublecodes.net/Ford/
Depending on what the code says, it may or may not help you. My first gut instinct is to pull all the sparkplugs, and see if any of them look and smell funny, like anti-freeze.
Old Apr 18, 2006 | 06:21 PM
Tommy1956's Avatar
Tommy1956
Pulled all 6. Looked good as far as normal wear. All were dry. Replaced 1 that could have been causeing the missfire.
Old May 2, 2006 | 05:03 PM
Jharger's Avatar
Jharger
My plug wires were causing these issues on my 1993 after about 150K miles - the misfire.
Radiator issue might be a bad cap.
Old May 4, 2006 | 07:46 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Pull and post the codes along with which of the three types it was. Codes are stored in CM, IIRC, for 50 duty cycles after the fault was first detected.
Along with radiator cap, pinched or obstructed return line from the burp tank. You can rule out the upper radiator hose as the culprit; the radiator cap has what amounts to a check valve and takes virtually no vac to open, thus allowing coolant return.
EPW1790
21
Mar 17, 2012 05:12 PM
daveengelson
Oct 26, 2008 01:24 PM
AmeriKen
13
Jul 26, 2005 09:29 PM
jfrank
Mar 30, 2004 08:47 AM
Donald Rohret
1983 - 2012 Ranger & B-Series
Aug 26, 2003 12:08 PM
