Can a 'puter re-learn after mods?
Old May 10, 2006 | 07:23 AM
  #31
Casey's Avatar
Casey
Originally Posted by Tenn01PSD350
C'mon Casey. Tell us the source of your info.
It comes to me in my dreams. Sometimes in the shower, too, but those visions are usually all wet!
Old May 10, 2006 | 04:13 PM
  #32
pmasley's Avatar
pmasley
Good answer Casey.
The reason that I really wanted to know is that my truck went into a mode (after the wife had driven it) the other night (limp home sorta), It would run up to 60 mph but no more. It was not blowing smoke, but there was no power (like a blown/loose boot, checked - none). I came home shut it off and did the visual check, then checked for codes - none). I unkooked the battery for about an hour. The next startup, it was back to normal. I know something is going on, just cannot figure it out.
Old May 14, 2006 | 07:05 AM
  #33
stockernavstar's Avatar
stockernavstar
ok, i just did the batt disconnect for about an hour. went to back out of my driveway and a a no peddal situation! floored it twice to get it to go and it came back! NEver had that before. So was that the pcm relearning the tps? Something was learning there.
Old May 14, 2006 | 08:58 AM
  #34
Casey's Avatar
Casey
Something was learning, or there is an intermittent problem? I know which one I believe.
Old May 14, 2006 | 11:32 PM
  #35
pmasley's Avatar
pmasley
Stocker, I am in the same situation. I have replaced the CPS twice. It will run great, then all of a sudden, it wnats to limp home. Like I said earlier, no codes. Unhook the batteries for a while, then it is back to normal. It did it tonite after installing the HPX line.
The light bulb above my head is getting dimmer on this one. Guess, I will find or borrow a ICM and see if that solves it.
indyraven
May 19, 2016 03:05 PM
cay5628
Modular V10 (6.8l)
Feb 28, 2013 09:22 AM
kfabe8
1997 - 2003 F150
Nov 17, 2012 01:00 PM
RobertH
Apr 1, 2011 08:58 PM
oddjobs2do
Aug 23, 2007 02:57 PM
