Frame restoration
Old Apr 23, 2006 | 12:03 PM
Joe T.'s Avatar
Joe T.
Frame restoration
Has anyone ever removed the rear leaf spring mount castings from the frame to clean and paint. Then, re-attached them with either rivits or something else ? ( 55' F-100 ) Thanks, Joe
Old Apr 23, 2006 | 01:45 PM
jaye's Avatar
jaye
I drilled mine out and replaced with bolts however, you are probably going to need new brackets, bushings, pins, etc.
Jaye
Old Apr 23, 2006 | 02:30 PM
sierraben's Avatar
sierraben
jaye, nice pics in your gallery.
The only thing I replaced on mine was the swing brackets and pins/bushings; along with the leaf springs; both on the front and rear.
Old Apr 23, 2006 | 03:03 PM
reamer's Avatar
reamer
Drilled them out to remove, repair, paint the frame liners, sandblast, Por-15 the frame and grade 8's all around. ('48 F-5)
Old Apr 24, 2006 | 05:47 PM
Joe T.'s Avatar
Joe T.
Thanks for all info, guys. How about any of the other cross members ?
Old Apr 24, 2006 | 08:32 PM
reamer's Avatar
reamer
Had to take all the cross members out along with the rear-front spring and the front-rear spring mounts off to get the liners out.
Over 100 #&%$ rivets. Swollen knuckes and burised fingers!
Old Apr 24, 2006 | 09:06 PM
Joe T.'s Avatar
Joe T.
This may be a dumb question but what do you mean by "liners" and would the '55 F-100 have them ?
Old Apr 24, 2006 | 09:32 PM
sierraben's Avatar
sierraben
I'm curious too.
At first I thought they were talking about leaf spring liners.
Old Apr 25, 2006 | 05:52 PM
Joe T.'s Avatar
Joe T.
I'm thinking they mean a bushing in the leaf spring mount. At first it seemed like some sort of inner frame rail like my '43 ****** jeep has. Thought my frame was missing something for a minute there.
Old Apr 25, 2006 | 06:32 PM
AXracer's Avatar
AXracer
The heavier trucks used the same frame but had inner liners like doublers in the frame to stiffen it.
Old Apr 25, 2006 | 06:47 PM
Joe T.'s Avatar
Joe T.
Thanks AX !
1966MN
Jan 5, 2015 01:10 PM
joe cowan
Jan 24, 2010 10:03 AM
Joe92F250
Sep 28, 2009 04:25 PM
Joe Tx
Offroad & 4x4
Aug 8, 2007 05:36 PM
Joe
Jan 9, 2002 01:01 AM
