Best Engine for Fuel Economy?
In light of another round of high gas prices, I thought this would be a good time to ask if anyone has focused on a good mileage engine with decent performance.
What are your opinions on a good economical all around daily driver engine/trans combo? Is it possible to get about 20 mpg avg. in a F1 or F100? I'm a little surprised with the weights being around 3300 lbs. or so that my trucks don't get better mileage, in spite of the shape.
Is there anything else that can be done to our beloved boxes to improve economy? With this thought in mind, I wonder if anyone will bring an "aerodynamically" designed truck to this years show. Haven't seen this theme so far at the show; figure it's just a matter of time.
Just curious,
Paul G.
Just curious,
Paul G.
As much as I would like to say a flathead or a Y-Block and since your set up for a small block. I would go with a 302 (That hurt) with better breathing heads, electronic (Again) fuel injection, T-5 with a 3:25 rear, and decent flowing headers.
Keep your foot out of it, and ride your bicycle as much as possible.
on
I think this is a conspirsy to get rid of all the gas guzzlers. It won't work on me, (yet) I'm leaving the FE in there. The Harley gets 50-52 MPG, so riding it whenever I can will compensate for truck. Back to the thread, my folks have a Crown Vic with a 4.6 that runs sweet and gets 22 MPG.
_________________________
XFM...
XFM...
Originally Posted by 51dueller
The 302 is only a bad truck engine in the 73 and up trucks due to a heavy truck, but due to lightness of the 48-60 trucks they make a fine engine. The 300 I6 is another good choice. The 223 is good but is a little underpowered stock (BTW I have driven all three of these engines.)
Oh, and I put a AODE behind the 302 with 5.12:1 gears (I got 36" tires) and it still gets pretty good gas milage. I can't say what it is because the speedo broke but I don't fill the tank very often and it only holds 13 gallons.
I have centered on the 300 I-6 with a ZF S542 5 speed. I might do a Cummins 6BT if I can find a Donor Dodge truck cheep!
I think with right gearing it won't be too bad (it also won't be a daily driver)
ANother choice would be a cummins 4BT (for a F1/100/2/250) or a 6BT (for an F2/250+)
There are Dodge trucks (2wd 3/4t) getting over 20mpg out there with "tall" gears.
To get good mileage you HAVE to turn them slow (gas or diesel)
Cheers,
Rick
Cheers,
Rick
on
So have I or I wouldn't have stated what I stated.
The 300c.i.er is a tight squeese, but it does everything it's supposed to & even more.
If I can chirp my tires w/ a Stock 223c.i.er, it's more than enough power for everything else.
Friends & aquaintences have had Nothing but bad to state about using the 302 in '48-'60 trucks, as in the power band is all wrong when using as a truck & poor mpg when not.
