Plastic Rag Joint
Old Aug 21, 2002 | 07:17 PM
William's Avatar
William
Plastic Rag Joint
While back someone asked for this part number! This is a Ford plastic rag joint Part Number D5TZ-3A525-A Ford calls this a Flange & Ins. Asy
William in Atlanta
Old Aug 22, 2002 | 08:58 AM
mlf72f250's Avatar
mlf72f250
Plastic Rag Joint
[updated:LAST EDITED ON 22-Aug-02 AT 09:58 AM (EST)]What models and years of trucks will it fit?
Old Aug 22, 2002 | 10:44 AM
William's Avatar
William
Plastic Rag Joint
65-79 power steer or manual. Maybe others?
William in Atlanta
Old Aug 22, 2002 | 11:10 PM
mlf72f250's Avatar
mlf72f250
Plastic Rag Joint
I've heard it's good to change those. My steering keeps geting better with every upgrade, but I'm not quite there yet. Polyurethane bushings are in -- what a difference! Sway bar is soon to be in as soon as I fabricate a plate for it.
How hard it the rag joint to put in? Do Ford dealers still stock those? I have a '72 F250 with PS, 360, and auto.
Thanks!
--Matt
Old Aug 23, 2002 | 10:17 AM
William's Avatar
William
Plastic Rag Joint
15 minute job.
William in Atlanta
Old Aug 24, 2002 | 09:24 PM
tallica2002's Avatar
tallica2002
Plastic Rag Joint
Old Aug 25, 2002 | 07:18 PM
Erik R's Avatar
Erik R
Plastic Rag Joint
Funny how this came up; as I was contemplating changing mine on my '71 F-250 CS, with P/S. I bought a replacement from NAPA, but the original joint appears to be riveted (?) with the safety dowels facing up and only unbolts from the steering column.
Do I have to remove the column from the truck and grind these off?
What alternative do I have?
Old Aug 26, 2002 | 06:28 AM
William's Avatar
William
Plastic Rag Joint
Erik, he joint should un bolt from the column (1/2 inch wrench X 2 bolts) The bottom slides off the gear splined shaft after loosening the collar. There is some grinding and re-fitting involved the first time you install one of those 10 dollar rag joints, next time it will be easier. Again, I recommend solving the problem once. Costs a few extra bucks but I never compromise on safety issues and I am picky! While you are there check the lower end of the steering shaft for play, if it wiggles around replace the lower bearing.
William in Atlanta
Old Aug 27, 2002 | 12:01 PM
Erik R's Avatar
Erik R
Plastic Rag Joint
Part # D5TZ-3A525-A is $70 plus tax............
I think I will slide my column back a little and do some grinding.......
Rag Joint fron NAPA was $12 and should last as long as I'll need the truck.
Good tip though, for those who can afford it
mrpotatohead
Dec 2, 2016 10:10 AM
vidaliaman
May 13, 2016 11:43 AM
greasy rider
16
Mar 14, 2016 01:00 PM
william16339
19
Sep 26, 2015 02:48 PM
william16339
Jul 29, 2015 09:58 PM
