Pull tranny with motor ??
Old Apr 20, 2006 | 06:52 PM
oldblues2's Avatar
oldblues2
Question Pull tranny with motor ??
Well I'm out here in the deasert, no garage floor, pulling motor out of f-250, need to work on number 7 cylinder while I'm doing all this I should change seals anyhow, should I go ahead and pull tranny to? If the wind blows I have to tarp think up. thanks for any input.
Old Apr 20, 2006 | 10:15 PM
elemint's Avatar
elemint
Do you need to fix the tranny? Not sure what you are asking.
Old Apr 20, 2006 | 10:25 PM
kdhannink's Avatar
kdhannink
when i pulled my engine, i took the tranny with it. i dont know if you have a manual or automatic. i assume automatic. just keep them hooked up together and it should come out fine.
Old Apr 20, 2006 | 10:31 PM
Chevy_Eater's Avatar
Chevy_Eater
Unless you need to pull the tranny just pull the engine by itself.
Old Apr 20, 2006 | 11:23 PM
BobbyFord's Avatar
BobbyFord
If you're not going to do any work on the trans, leave it in the truck.
Old Apr 21, 2006 | 06:25 AM
lee armistead's Avatar
lee armistead
Question Desert sand
I believe that I understand your question having lived in the Arizona desert for over 30 years. Sand and wind!! I have always pulled the engine and tranny together. Reassembly is easier since you'll probably have to move the tranny around to get alignment on the shaft when you reinstall. Also prevents infilteration of the sand on exposed components. I don't know what your problems is with the #7 cylinder. If you explain maybe there is a way of dealing with it without pulling the engine!
Old Apr 21, 2006 | 09:55 PM
oldblues2's Avatar
oldblues2
sorry I didnt explain good . The #7 cylinder has 28 lbs and with oil it has 60 lb,
the tranny has a hesitation when first starts in the mornings, but is find the rest of the day ,its a c-6 so instead of trying to replace seals under the truck, should take tranny out and fix it?? right, Was hopping there was a burnt valve, also a slite knock to, there has to be something going on in that cylinder. was going to replace the 352 witha 360 that has a burnt ex valve, but the price of gas now days cant afford to fix both engines so. going to repair the original engine, sounds good, right???
Old Apr 24, 2006 | 06:12 AM
lee armistead
Yep, sounds like a good plan. Lee
ajk8606
Dec 8, 2014 05:09 PM
dylansf23
Jul 5, 2014 10:24 AM
AndysFords
Sep 29, 2008 10:00 PM
fordfan302
15
Feb 14, 2008 09:29 PM
1ole4d
23
Sep 30, 2002 05:08 PM
