Hi. I have the check engine light on and had tested and was told i have code 172. Can anyone help? The engine is idleing rough, and gas mileage is 12 mile per gal.
what year Aero, 172 indicates 3 letter codes from OBDI EEC-IV pre '96 system
172=HEGO sensor circuit indicates lean.
1. Failed O2 sensor...if more than 50k miles on present one replace
2. with the rough idling, look for a vacuum leak with a spray can of throttle body cleaner or carb cleaner, spray vac. tubes and fittings....engine smoothes out=leak found
3. IAC dirty and sticking wide open
clean or replace
4. MAF dirty and giving false air flow readings
clean or replace
5. Failed ECT sensor giving false hot coolant signal
replace
do 1 step at a time.....disconnect neg bat. lead after each to reset KAM in ECU and drive for 10-20 miles checking for improvement
