Interior Lighting Wiring
Old Aug 22, 2002 | 07:57 PM
1968F250LWB's Avatar
1968F250LWB
I have all the wiring for the dash lights and dome lamp figured out. Both are fed power from the light switch. My question is which part of the switch feeds these circuits. By that I mean is it the rheostat or is it fed power by pulling the **** out.
Thank you,
Russell
1968 F250 LWB 300-6
FORD=First on Race Day
#88 Dale Jarrett
#21 Elliott Sadler
#97 Kurt Busch
#28 Ricky Rudd
Old Aug 22, 2002 | 08:09 PM
Mil1ion's Avatar
Mil1ion
Dash lights are a Blue/red wire.
http://www.clubfte.com/users/mil1ion/2cents.gif
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
64 1/2 Mustang Pre-World's Fair Car #8092
68-Mustang 289 2v-Sunlit Gold
[/font]
Old Aug 22, 2002 | 08:12 PM
1968F250LWB
Come on Dennis! I expect better out of you. At least read my post before replying.
Russell
1968 F250 LWB 300-6
#88 Dale Jarrett
#21 Elliott Sadler
#97 Kurt Busch
#28 Ricky Rudd
Old Aug 23, 2002 | 01:15 PM
sparky's Avatar
sparky
I will take a shot at it, off the top of my head as my diagrams are packed away. The dash lights are fed power from the rheostat and the dome light is fed from a switch on the rheostat that is made when the headlight switch is rotated fully to the right (ps right is a guess it could be left).
So the rheostat dims and brightens the dash and the switch turns the dome light on/off with no dimming.
Sparky
Old Aug 29, 2002 | 07:42 PM
mk's Avatar
mk
For the dash lights, power is fed by pulling the **** out.
Old Aug 30, 2002 | 04:04 AM
1968F250LWB
I figured out the problem. I need a new headlight switch. I might have been able to use the old one with some cleaning but curiosity got the best of me and now I have about 30 pieces of a headlight switch! LOL Thank god they ain't that expensive.
Russell
1968 F250 LWB 300-6
#88 Dale Jarrett
#21 Elliott Sadler
#97 Kurt Busch
#28 Ricky Rudd
Old Aug 30, 2002 | 04:26 AM
jowilker's Avatar
jowilker
Old Feb 28, 2003 | 06:48 PM
1968F250LWB
Ok I got my new headlight switch installed but the dome light still doesn't work. It has a brand new bulb in it. I do not have the door switches in the circuit so what I have is:
Light Switch-->Black/Blue Stripe Wire--->Connector--->black/blue stripe wire---->connector--->light housing.
Sounds pretty simple can someone please help.
Old Feb 28, 2003 | 07:19 PM
Mil1ion's Avatar
Mil1ion
You need the switches.
Or jumper the wires.
Old Feb 28, 2003 | 07:30 PM
1968F250LWB
Dennis,
My truck never had the switches or the wires going to them. From what I can gather from the wiring diagram the way it is hooked up is correct for just having a light and no switches. There is another schematic that shows the black/blue stripe wire coming from the switch going to the door switches then from the door switches to the light, (or so). I turned the **** on the headlight switch all the way to the left and I have 12VDC from the center post of fixture to outer ring of fixture. Put bulb in, no light. Try new bulb, no light. Measure resistance of bulb, just in case, small ohmage (good). Now what?
Edit: My schematic shows a ground wire coming from fixture but mine doesn't have a wire. I was guessing that it gets this ground through the housing so I scraped the mounting points free of all paint and primer and tried it that way. Still no light.
Old Feb 28, 2003 | 07:49 PM
Mil1ion's Avatar
Mil1ion
Have you had the dome light assembly out yet?
Old Feb 28, 2003 | 07:50 PM
1968F250LWB
yes and all looks well to me.
Old Feb 28, 2003 | 08:20 PM
I_Thnk_Ford's Avatar
I_Thnk_Ford
rubberpants here.
Have you tested the socket? I had a tail light giving me the same problem before. It had a build up on the little contacts inside the socket. I would test the socketwith a meter/t-light. Maybe it's just gunk.
LOL
Robert P.
Old Feb 28, 2003 | 08:22 PM
1968F250LWB
When I measured the voltage I was inside the socket with the bulb removed. The socket looks brand new. Thank you for the suggestion though.
I hope you took the whole rubberpants thing as a joke because that is how it was meant.
Old Feb 28, 2003 | 08:29 PM
I_Thnk_Ford
I takes more than that to ruin my day.
Yes, I took it as a pun.
If you have power at your socket and a good bulb, try running a ground wire from somewhere with the bulb in the socket, and then touch that good grounded wire to the outside of the socket. Sounds more like a ground problem.
Robert P.
