single or dual plane?
Old Jul 10, 2002 | 11:30 AM
cgmh's Avatar
cgmh
does anyone have any input on wether the single or dual plane manifolds work better on the fe engine.
Old Jul 10, 2002 | 03:29 PM
69crewcab's Avatar
69crewcab
For the street run a DUAL PLane...Keep the single plane manifolds
to Nascar
Old Jul 10, 2002 | 11:23 PM
big block power's Avatar
big block power
I have a friend with a single plain on a 400 cant say
the brand here though, it'll haul major butt when it's in
the high rpm range,but the car can barely pull its self
onto a ramp type hoist without stalling or lugging at
low rpm. dual plain is more torque and hp lower down.
Fe power
Old Jul 11, 2002 | 04:23 AM
karljay's Avatar
karljay
It really depends on the intake, the Holley and Edelbrock streetmaster are single plane low rpm intakes with small runners. The Edelbrock Victor is a single plane that is VERY high rpm. You really have to look at the rpm range of the intake.
For most FE's the edelbrock RPM is an excellent choice dual plane. Otherwise the stock S code iron 390 GT intake is about the same as the edelbrock performer intake and works very well on the street and can be had for < $80.
Old Jul 11, 2002 | 10:26 AM
buzzard's Avatar
buzzard
Dual, unless your FE is a 427.
I've got the Edelbrock Performer RPM and love it.
Old Aug 31, 2002 | 07:56 PM
rmcgraw351's Avatar
rmcgraw351
single plane for high rpm horsepower, dual plane for low to mid range torque.
Old Aug 31, 2002 | 11:23 PM
krazdndenver's Avatar
krazdndenver
An intake manifold is designed to work best at set rpm's. Also they are designed as part of a package- if you replace a intake manifold by its self you will se results, but if you change the cam with it as part of a package you will be much happier.
Robert
72 F-00
5.0L w/AOD
Old Sep 1, 2002 | 04:52 AM
inliner's Avatar
inliner
Colo79Ford
Oct 7, 2008 11:27 AM
polcat
Aug 21, 2004 07:45 AM
zsir
Feb 21, 2003 11:44 PM
bigredtruck
Oct 23, 2002 12:20 PM
Big Blue4x4
Jul 2, 2002 12:16 AM
