Leaky T-case
Old Apr 18, 2006 | 08:08 PM
Dieseldan7.3's Avatar
Dieseldan7.3
Leaky T-case
My transfer case has been leaking ever since I bought the truck and I figured its about time i put some fluid back in it. About a year ago i filled it with 80-90 gear oil but I am not sure what it actually takes.
Does it use ATF like the ZF5 or gear oil?
Old Apr 18, 2006 | 08:23 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Not sure which case is in your truck, but if it is aluminum and chain driven it takes ATF.
Old Apr 20, 2006 | 07:08 AM
PLC7.3's Avatar
PLC7.3
Caution 80/90 used in the BW1356 and operated in cold weather will tear off the oil pick in the TC. Only use ATF as stated above. Only thing now is to determine if the pickup is still in tact, if not you will burn up the mainshaft.
http://www.wildercafe.com/fordtech/
chevenstein
Oil & Lubrication
Oct 19, 2007 11:32 AM
lightninsniper
1978 - 1996 Big Bronco
16
Sep 25, 2003 11:43 AM
willywonka316
Jan 2, 2003 06:36 PM
fordguy76
Oct 18, 2002 03:01 PM
wildjon300ci
Jun 15, 2001 07:21 PM
